#59850 - 16/01/2002 17:18 Error installing Emplode 2.0b7
BinaryC
When i try to install Emplode 2.0b7, I get "The msiexec.exe file is linked to missing export msi.dl:222" I'm running Win98SE with Windows Installer 1.1 (the newest version on Microsoft's site). Any idea what could be wrong?
#59851 - 16/01/2002 17:29 Re: Error installing Emplode 2.0b7 [Re: BinaryC]
tarkie
Check out this link
and, although I hope it's not connected, this one too
M2a/Smoke/60gb/Tuner!! Thanks Joe M2a/Blue10gb Thanks Ian!
#59852 - 16/01/2002 18:07 Re: Error installing Emplode 2.0b7 [Re: tarkie]
Hey, good links. The ":222" thing looks like it might be the right one. Thanks for posting those.
Personally, I think this whole "Microsoft Installer" stuff is awful. I much prefer the older releases of InstallShield that are fully self-contained. I have tried to convince the empeg guys that it's better to use the older version of InstallShield, but they have their reasons for using MSI.
#59853 - 16/01/2002 18:15 Re: Error installing Emplode 2.0b7 [Re: tarkie]
I too had the identical problem today, for the first time. On Windows 2000 Pro, SP2.
#59854 - 17/01/2002 09:54 Re: Error installing Emplode 2.0b7 [Re: tarkie]
Ok I tried both solutions (well, basically 1 is contained in 2), unsuccessfully. This is bad, I can't install emplode on my pc in the office! This is the first time that happened to me. I installed on WIn2k Server and professional at home, WinXP Pro, and now on this FRESH, newly installed win2k pro there's no way I can proceed. After doing what said in the links you posted, now I don't get any error. Simply installation stops and get the message sayin that it was interrupted, windows was not modified, and to retry.
#59855 - 17/01/2002 11:11 Re: Error installing Emplode 2.0b7 [Re: Taym]
and you're sure the downloaded copy of emplode is "good"?
#59856 - 17/01/2002 17:44 Re: Error installing Emplode 2.0b7 [Re: tfabris]
Well, at this point, not anymore. You're right, I'll try to re-download it tomorrow.
#59857 - 18/01/2002 02:25 Re: Error installing Emplode 2.0b7 [Re: tfabris]
I wasn't. Redownloaded and installed successfully
#59858 - 18/01/2002 13:04 Re: Error installing Emplode 2.0b7 [Re: Taym]
Thanks, I will strengthen the language in the FAQ regarding troubles with upgrades.
#59859 - 18/01/2002 14:18 Re: Error installing Emplode 2.0b7 [Re: Taym]
mtempsch
I'll say it again; md5sums would be very handy...
#59860 - 19/01/2002 08:33 Re: Error installing Emplode 2.0b7 [Re: tfabris]
That's going to be good. Anyway unfortunately in my case that copy of emplode had been used before successfully, so I believe it got corrupted on my hdd for some reason I am still investigating. So I did not even consider that could be the problem. Thanks again for suggesting it to me!
