#61156 - 19/01/2002 08:55 Display Server
kojak71
I've installed v1.1 on top of emplode 2b7 and Hijack. Manage to connect to the eMpeg via the ie 6 using the empeg's IP address, but all I get is the directory structure and no applet. Am I missing something really obvious?
#61157 - 19/01/2002 09:48 Re: Display Server [Re: kojak71]
Nosferatu
Loc: France, Champagne
If there is no index.html file on the root filesystem, the HTTPD server will act as as a FileBrowser.
Mandiola has made scripts and html stuff to control the player via web browser :
Mandiola Stuff
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#61158 - 19/01/2002 11:27 Re: Display Server [Re: kojak71]
on top of emplode 2b7 and Hijack. (...) all I get is the directory structure and no applet. Am I missing something really obvious?
Yes, you are missing something really obvious.
Both Hijack and Displayserver are HTTP servers. Web servers, by default, run on port 80. Disable or remove hijack and displayserver will work. I do not know if Hijack has a way to change the HTTP server's port number, but that would probably work, too.
Also, I think there's a way to make displayserver run on a different port, also, so you could try that as well.
#61159 - 19/01/2002 12:10 Re: Display Server [Re: tfabris]
kojak71
Thanks Tony, it seems to have done the trick, now to experiment and see if I can get both Display Server and Hijack to live together
#61160 - 19/01/2002 13:03 Re: Display Server [Re: Nosferatu]
Alan
Loc: Cedar Grove , IN
Hyperterminal drops you into empeg/bin, whats the command to go up 2 directories to root?
home page
#61161 - 19/01/2002 13:07 Re: Display Server [Re: Alan]
mtempsch
'cd ../..' which moves up two directories, or 'cd /' which cd's to / directly
