#63182 - 25/01/2002 13:50 Emplode question
ashmoore
Loc: TX
Is there any way I can run emplode without having the player connected.
I want to be able to make my changes in emplode then connect up at the end and synchronize.
That way I can take a while to make my changes before syncing.
Any bright ideas? or is this simple?
========================== the chewtoy for the dog of Life
#63183 - 25/01/2002 14:01 Re: Emplode question [Re: ashmoore]
Currently, Emplode is just a "dumb terminal" that only works with the database stored inside the player. None of its database information is stored on the local PC.
This is actually an advantage. It means you can take the player to any PC and work on its music without having to worry about whether or not the local PC database is up-to-date. But it also means that you do have to connect to the player to get the database information before you can work on it.
Turning Emplode into a full offline bi-directional music organization system is in the long-term plans. Don't know how long this will take. But at the moment, it doesn't work that way.
#63184 - 25/01/2002 14:07 Re: Emplode question [Re: tfabris]
ashmoore
Loc: TX
Thanks Tony!
That would explain the lack of disconnected functionality
#63185 - 25/01/2002 15:31 Re: Emplode question [Re: tfabris]
papinist
Loc: Italy
This means that I can even use two units with the same pc without messing up the two databeses, right?
(This question has to be one of my next post:))
Stefano
#63186 - 25/01/2002 15:38 Re: Emplode question [Re: papinist]
mtempsch
Right.
#63187 - 25/01/2002 15:39 Re: Emplode question [Re: papinist]
warsaw
Loc: Colorado
You sure can. I do it all the time.
