#63574 - 26/01/2002 22:08 How do I use Hijack kernel in MKIIa
frekin
I installed the Beta7 developer upgrade and software beforehand, and everything works fine (haven't tried it in a car yet though). I downloaded the newest pre-built kernel, v151.hijack.v200b8.mk2.zImage, and used LogoEdit.exe to send it successfully to the player. Now the player stays in standby mode no matter what I do, through multiple power cycles. Only reupgrading it using the SonicBlue software brings it back to life. I'm missing something here...what is it?
#63575 - 26/01/2002 22:44 Re: How do I use Hijack kernel in MKIIa [Re: frekin]
Terminator
Loc: Dallas, TX
maybe a corrupt download. Mark has probably gone through 3 versions since your post, so give it another try.
Sean
#63576 - 27/01/2002 01:15 Re: How do I use Hijack kernel in MKIIa [Re: Terminator]
mtempsch
As Sean says, could be a corrupted download. Try running md5sum on the zimage file.
My copy of v151, which has been successfully installed, returns the following from md5sum: \3bca07933c8a23ab5dee7cb68a7563b9 (not sure if the \ is supposed to be part of the sum or not, but if the rest matches you're OK)
Do you have any odd stuff in config.ini?
#63577 - 27/01/2002 02:18 Re: How do I use Hijack kernel in MKIIa [Re: mtempsch]
frekin
Eureka! I grabbed md5sum and ran it on the file I had downloaded earlier:
md5sum -b v151.hijack.v200b8.mk2.zImage
a84823f817058ab8994d701616290099 *v151.hijack.v200b8.mk2.zImage
Then I used Intellitamper (www.intellitamper.com) to download the 1.51 kernel directly from the Hijack site:
3bca07933c8a23ab5dee7cb68a7563b9 *v151.hijack.v200b8.mk2.zImage
I uploaded it with LogoEdit, and it works great. Thanks for the tip.
One last thing...are there any detailed instructions for using the Hijack kernel? I can find a feature list on the home page, but with so many addons, it seems strange that I can't find a readme or docs anywhere. Does everyone just play around with it until they know how to use all its features?
#63578 - 27/01/2002 03:19 Re: How do I use Hijack kernel in MKIIa [Re: frekin]
mtempsch
Sort of... Most of the stuff available through the menus are pretty self-explanatory. What I haven't played with is the IR-translations or tweaking the VolAdjust settings(no need). Just noted that there are links to explanations for those two...
What commands that are available for ftp is listed if you send a 'HELP' and/or 'SITE HELP' command...
HiJack has been under very rapid development, features has come and gone (SITE EXEC for instance) or changed behaviour slightly - documentation hasn't really been able to keep up. I think there was someone who volontered to start on a tutorial (Mark was asking for him recently - or was it a general cry for a tutorial writer?) but it's not here yet.
If anything has you stumped and you can't find it on Marks site or in the FAQ, don't hesitate to ask here - generally you'll have an answer in no time...
#63579 - 27/01/2002 09:19 Re: How do I use Hijack kernel in MKIIa [Re: mtempsch]
frekin
Ironically, after posting my last message, I played around with it and figured everything out except ir translation, hehe. I even grabbed some tracks off of it with the FTP server. Thanks for the tips.
