#66772 - 04/02/2002 13:48 Insert, Append, Replace from a Search
svferris
Loc: San Diego, CA, USA
I was wondering if there is a way to search for a song, and then insert/append/replace it into your current playlist. I tried holding down the bottom arrow (like you do when in the playlist menu), but it didn't work. Ended up selecting the one song and wiping out the rest of my playlist.
#66773 - 04/02/2002 14:31 Re: Insert, Append, Replace from a Search [Re: svferris]
jloew
Loc: SF Bay Area
You have to set the search "mode" using the remote. The button is on the right side and is labeled "mode". You get the same 3 choices as hold-down-button trick.
The current mode is displayed in brackets on the top line like this [Insert]
MkIIa [blue]BLUE[/blue]
