#67780 - 06/02/2002 10:35 Emplode request
MikeS
A couple of very minor points:
1. I second the request for a “cancel” button during synchronization (spell it correctly please ). I use USB for printing, and if I need to print while synchronizing – agony.
2. Related: I would like a “throughput (Kps)” and “Time remaining” display during synchronization.
Q: will the Rio Riot use the same emplode software?
#67781 - 06/02/2002 11:42 Re: Emplode request [Re: MikeS]
1. It's a PITA -- we'd need to drop out of synchronising, and finish the job safely. This isn't that easy, so it's always been a low priority. It won't make it into v2.0 final.
2. So would I, but then people would know how slow the protocol really is . I started hacking on it a while ago (you might notice the "Estimating Transfer Size" item appear in the sync dialog in the next beta. However, there's still quite a lot of work to be done to it. It probably won't make it into v2.0 final.
No, the Rio Riot will not use emplode.
#67782 - 06/02/2002 13:04 Re: Emplode request [Re: Roger]
MikeS
Hmmm, so tell true, will there be a 2.1? a 3.0?
What about source for emplode?
