Howdy.. I cannot get jemplode to install in linux. First of all, Java has the worst documentation ever.. first I installed the JDK, then later tried the JRE just in case the JDK did not come with a virtual machine..
Finally got both installed fine, jemplode complains about wanting a JVM in my path.. which is odd, since most programs want your JAVA_HOME environment variable to be set. Oh well, I added the proper directory to my JAVA_HOME and my PATH..
jemplode2.bin still says:
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
No Java virtual machine could be found from your PATH
environment variable. You must install a VM prior to
running this program.
I realize this is a work in progress, but it seems to lack even the slightest bit of documentation for the most basic of installs. It doesn't help that Sun's Java stuff has terrible documentation as well (I've installed it countless times on several unix platforms and it's always a hassle)..
thanks!
- reid
