#67956 - 06/02/2002 18:30
WMA files??
Loc: SF
Probably should be in FAQ (didn't find) thought I read somewhere that WMA was supported in the recent Rio car players? was I smoking?
Thanks, sorry if it's a FAQ
#67957 - 06/02/2002 18:50
Re: WMA files??
[Re: AlB]
It will/should be by the time 2.0 is final.
#67958 - 06/02/2002 19:05
Re: WMA files??
[Re: AlB]
Did you try typing "WMA" into the search box? 'Cause when I tried it, it resulted in a hit on the following entry.
#67959 - 06/02/2002 21:57
Re: WMA files??
uhhmm, as of version 2? aren't we on v2.07 now.. still no support is there?
#67960 - 06/02/2002 22:04
Re: WMA files??
[Re: rockstar]
Loc: Dallas, TX
2.07 BETA . Betas usually precede a final. The reasons have been hinted at in multiple recent threads, i can't remember which though.
#67961 - 07/02/2002 01:35
Re: WMA files??
[Re: Terminator]
No, 2.0 BETA7 ![](/images/icons/wink.gif) . It's the seventh beta version of v2.0
2.07beta implies that it's a beta of version 2.07, which would be _after_ 2.0. It's not, it's before.
#67962 - 07/02/2002 01:54
Re: WMA files??
[Re: rockstar]
No, we haven't even reached 2.00 yet. We're still on the betas preceding 2.00.
#67963 - 07/02/2002 05:26
Re: WMA files??
[Re: robricc]
It's in the Beta that the alpha team have right now.
#67964 - 07/02/2002 10:14
Re: WMA files??
ahh gotcha, i think i forget about the regular release stuff since i have probably never installed it
#67965 - 08/02/2002 17:15
Re: WMA files??
[Re: AlB]
Loc: SF
So now we have WMA in Version 2.0 b11!!! Very cool! BUT wait...I spent last night exploring various rip/encode schemes and through my Paradigm A20's heard some differences but nothing truly dramatic. Where does WMA fit in the scheme? some say the qulaity is better and size is smaller....It is certainly easier to just fire up a CD on Windows and download the music to WMA format vs the task of setting up audiograbber-LAME system, but as with all Gatesian sofware i suspect there is more to the story. what say all the ABM people out there???
#67966 - 08/02/2002 20:47
Re: WMA files??
[Re: AlB]
If you want to make tiny files, use WMA. If you want to make files that just sound as good as they're going to get, use MP3. Simple.
#67967 - 09/02/2002 13:58
Re: WMA files??
[Re: hybrid8]
i sorta don't agree with that statement.. i think if you are used to say rupping at 192 with lame, you will get teh same file size aned a MUCH better sound with wma..
now i fyou go 320 with lame.. or use the r3mix setting it will be a lot closer in sound.. but not justifiable for 2 times the space imho.
FWIW i notice less noise with wma.. over eac/lame/r3mix encoding.
#67968 - 09/02/2002 14:17
Re: WMA files??
[Re: rockstar]
LAME doesn't rip. It encodes. Ripping != encoding. The ripping process is always the same, no matter what encoder you choose.
If you want to compare two encoders, then you do all your testing with the exact same WAV file. You also contradict yourself in your statements. Using r3mix settings in LAME will, on average, produce smaller sizes than 192CBR.
Anyway, use what you like. That's why WMA support is in there to begin with. But if you're really concerned about how something sounds to you, then you should obviously test your own tracks. LAME has a lot of options that will go far beyond the quality of not supplying any options at all.
#67969 - 09/02/2002 14:21
Re: WMA files??
[Re: hybrid8]
i never said i ripped with lame, take a look back and notice teh EAC part of the equation.
None of the file i rip wth the r3mix settin are smaller then 192 cbr, if one of my mp3's is 5.5 megs with 192, you can bet it is 8-9 with r3mix settings.
and furthermore the ripping process is not the same.. especially if you have damaged discs.. eac take 3 hrs to read a scratched disc that windows media can do in an hour.
Edited by rockstar (09/02/2002 14:22)
#67970 - 09/02/2002 14:25
Re: WMA files??
[Re: AlB]
Very subjective. The generalisation is only correct when comparing to Xing type MP3. However when comparing to LAME you'll find on low bit rate WMA (e.g. 64kbps which is supposed to be the equivalent in quality to a 128kbps MP3) is noticeably worse, even without headphones, because so much of the treble detail is lost. IMO MP3pro makes a better job of lower encoded files, but then of course MP3Pro is not a widely supported format. I don't know at what bit rate WMA does starts to begin to come into it's own, but I shall be experimenting with WMA in the next couple of days just out of curiosity
#67971 - 09/02/2002 14:27
Re: WMA files??
[Re: rockstar]
You did it again. You called LAME a ripper. "file i rip wth the r3mix settin "
Ripping is ripping. Encoding is encoding. It's obvious your tests are using two different rippers and two different encoders. That's more than one variable, which means your test for end quality is invalid when trying to qualify the encoder.
Like I said, do both WMA and MP3 encodes from the SAME wav file. And you want to know why EAC takes so long? Because it's doing a far superior job to Windows Media Player.
Anyway, if any of your rips are taking an hour, you either have a disc that should be replaced or a very poor CDROM drive.
You can easily use emplode to see what the average bitrate is on VBR files. Mine fall into the ranges mentioned on the r3mix site. They are NOT, on average, as large as 192kbit tracks.
#67972 - 09/02/2002 15:45
Re: WMA files??
[Re: hybrid8]
whatever
Edited by rockstar (09/02/2002 16:35)
#67973 - 09/02/2002 16:11
Re: WMA files??
[Re: rockstar]
I'm sorry you have such a problem staying civil. I can't read your mind and can only go by what you're writing.
I have over 5900 tracks on my player right now. All slight variants of r3mix. So when I mention "average" I'm actually talking about an average. If you're going to pick one specific track, then just don't represent it as an average. I have verified the information made public on the r3mix site.
Now, if you go back to what I orginally wrote.. Encode with whatever you want. But don't get bent out of shape when you put your foot in your mouth and when you simply provide information that doesn't jive with that elsewhere. Most of all, think twice before telling someone to do what you just mentioned.
#67974 - 09/02/2002 16:32
Re: WMA files??
[Re: rockstar]
I don't have any experience with WMA, so I can't comment on that. But I do have about 200 albums encoded with the r3mix preset, so just as a point of information, the average bitrate of my music collection (only valid for the types of music, I've chosen to buy) is about 197 kbps, negligibly more than 192. With regard to "mr. smartypants's" other points, they seem perfectly valid to me, I don't see anything that warrants this explosion of terms like "STFU" Lets try to keep the posts more objective if we can here. Feel free to ignore me if you want, of course.
John
1998 BMW ///M3
30 GB Mk2a, Tuner,
and 10 GB backup
#67975 - 09/02/2002 16:40
Re: WMA files??
[Re: johnmcd3]
point taken..
i get set off by people that belittle others or attempt to over the internet.. there are a lot of things to learn from a lot of people.. when i read multple posts on the same day by the same person attempting to belittle someone(s) it bothers me.. especially when they have racked up an astounding 1000 posts in 3 months..
bottom line is, if you don't have something nice to say and your whole point is to try to make someone feel stupid.. don't post.
#67976 - 09/02/2002 16:42
Re: WMA files??
[Re: hybrid8]
fwiw this test was done with MULTIPLE wav's i was exhibiting ONE example.
#67977 - 09/02/2002 16:49
Re: WMA files??
[Re: rockstar]
Great. I have tracks that also average to 240kbit or so and some others that come to about 160 (or a bit lower).
BTW, if I was trying to belittle you, I wouldn't have bothered to be helpful at the same time. Maybe hop on over to the OffTopic forum for a little taste of Mr.Happy.
#67978 - 09/02/2002 20:41
Re: WMA files??
[Re: Roger]
Loc: Dallas, TX
oops you are right. I dont know where I got 2.07 from.
#67979 - 09/02/2002 20:48
Re: WMA files??
[Re: rockstar]
Loc: Dallas, TX
If you can't hear anything above 13 or 14khz, then WMA is the encoder for you. However, some of us haven't lost enough hearing to not notice the difference yet.
Sean
#67980 - 09/02/2002 20:56
Re: WMA files??
[Re: hybrid8]
No thanks. I'll trust your judgement on what Mr. Happy tastes like.
#67981 - 09/02/2002 23:28
Re: WMA files??
[Re: Terminator]
it would be really interesting to see the graphs proving that.
#67982 - 10/02/2002 10:07
Re: WMA files??
[Re: rockstar]
Loc: Dallas, TX
I'll find you some. :-) But it doesn't really matter what the graphs show, its really up to each person to listen to each and come to their own conclusion. Everyones hearing is different, and the models these encoders use assume that everyones hearing is the same.
Sean
Edited by Terminator (10/02/2002 10:09)
#67983 - 10/02/2002 11:19
Re: WMA files??
[Re: Terminator]
no i really asn't trying to be a smartass, i would like some if you can find them.
#67984 - 10/02/2002 13:36
Re: WMA files??
[Re: rockstar]
Loc: Dallas, TX
Ok, I found some. They are here: http://ff123.net/peacefulspecview.html
The whole site is pretty good for codec info. I tried the hearing test that was linked there. Interesting stuff.
http://ff123.net/
You can see in the wma graph where the dropouts start at 13khz, there are some spikes up to 15khz, but they would probably just sound like ringing to me. The lame graph is cut off at 16khz due to a lowpass, but there are fewer dropouts.
Sean
#67985 - 22/02/2002 14:40
Re: WMA files??
[Re: AlB]
Loc: Denver, Colorado
I have a 71.4MB .wma file that shows up as "Invalid file format" when I try to play it. It is 5hr 6min long. Properties say 32kbps, 44kHz, stereo.
Appartently the Rio Car can not play protected wma files. How do I tell if it is protected? It plays on Windoze Media Player 6.04 (the latest available for NT4) and I loaded it via Jemplode 2b11 and my player is at 2.00-beta11.
