Instead of the columns currently used in the UI for the equaliser, it would be much nicer if we could see a
graphic representation of the individual centre frequencies and how they interact with adjacent bands.
Currently, each column just represents a frequency, and the height represents the pass/boost level for that frequency. Because all the columns are just placed next to each other, there is no way to see the relationship of that particular frequency band to the audio spectrum of the player (i.e. the position of the frequency band centre in the audio spectrum), or to other bands. Additionally, a column does not let us see the Q (the bell curve showing the envelope of the filter). Finally, there is no way to view the net envelope created by the interaction of the frequency bands. We already have the high-resolution Frequency analyser graphics from Toby, but it is difficult to envisage the relationship between the current filter settings and the displayed spectrum, especially since the graphic does not display axes or calibration.
So, here are the requests; a re-design of the UI of the equaliser to show the equaliser bands as individual envelopes within the audio range of the empeg (20Hz - 20kHz?), and the net envelope resulting from the individual frequency centres, amplitudes and Q values. This would allow you to very acurately set up your empeg to drive your amp correctly according to the characteristics of the amp (e.g. boost frequencies where the amp rolls off, or cut where it peaks) and also in a more subjective manner (e.g. tailor the sound of the setup to suit your ear in the particular car you are using the empeg in).
It's a lot of work, I admit, but if it was designed to use the maximum screen real estate (as per the way Toby's graphics do) it would be an impressive addition to the player both for ease of use in setting up your sound and for demoing to gullible friends!!! (by far the most important, of course
Secondly, add to the spectrum analysis graphics the option to switch in axes displaying calibration, most importantly frequency, to the display so that it becomes easier to look at the frequency content of the playing music.
Lastly, and mst difficult, display as an overlay the filter envelope from the current equaliser settings.
