That's what I just tested. It works fine on my player. Weird. Throw another script in that directory that just echoes out some text to stdout (``echo testing'', for example) and watch the startup output to make sure that it's getting run. You should see this text. It may be easier to see if you have multiple lines of text output. It should occur shortly after ``Trying to unmount old root'' and shortly before ``Mounting proc''. Also, make sure that /bin/hijack is set as executable, if you can. The scripts need not be.
