OK. So on Abbey Road, there's that medley of 10 songs or whatever at the end.
So if I create a playlist for Abbey Road, then create a playlist underneath that containing that group of songs (ordered where it should be within the Abbey Road
playlist) and set it as a Single Tune (and "Don't Shuffle" if/when that gets added)... Then I choose the empeg-car playlist. The play hops along happily.
When it hits that group, will it play it starting from the beginning, all the way through? That'd be my desired behavior.
As for the general usage of "Treat as a single Tune", perhaps there should be two options... "Play as a single Tune" and "Skip as a single Tune" or something along those lines, so that when the player is adding that playlist to its "current playlist" (or play order, or whatever), it would stick them all in back to back and in order, but I could still skip through the individual bits, or if "Skip as a single" is set, it would jump over the whole thing.
brian
