#73225 - 19/02/2002 15:49 Help needed identifying amplifier connections
AndrewT
Loc: Oxford, UK
I have a 2nd user amp on SOR from a colleague provided I can get it working, the only problem is that there are 3 screw terminals I can't identify.
Inputs & outputs are obvious, the 3 connections I'm struggling with are labelled as follows:
CON
B+
V+ .... with REM opposite
Presumably they must be for +12v, Gnd & Pwr-On and they are all of equal size.
The amp is an old(ish) Jet Sound JS-4080P 50Wx4
I have my hunches but the terminology used on the screen printed legend seems somewhat illogical to me, can anyone help please?
Rue
Edited by Rue (19/02/2002 16:27)
#73226 - 20/02/2002 16:23 Re: Help needed identifying amplifier connections [Re: AndrewT]
AndrewT
Loc: Oxford, UK
Ok, I think I've worked this out but I had to take the unit apart to do it.
If anyone's interested the 3 unknown connections are as follows:
CON Ground (CON possibly should read 'COM')
B+ +12v Supply (Battery +?!)
V+ On/Off control
This AMP is of Chinese origin and a budget device at that, my guess is something was lost in the translation when they chose the panel markings
#73227 - 20/02/2002 19:52 Re: Help needed identifying amplifier connections [Re: AndrewT]
tracerbullet
Loc: Minnesota
B+ is definitely the constant power lead, I've had several Phoenix Gold and Clarion items labeled this way. Not positive about the others but I'm *pretty sure* you're right...
You might hook up that B+, then use a multimeter to each of the other two (one lead to the terminals, one to ground on the car somewhere) and see which one flows power through.
Edited by tracerbullet (20/02/2002 19:55)
