#74341 - 23/02/2002 15:15 player hangs at boot logo
test123
After doing a sync with emplode, the player would hang at the boot logo. Attaching my laptop to the serial port gave me this:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v208 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Sat Feb 23 14:48:50 EST 2002
empeg-car player (hardware revision 9, serial number 40103724)
Command line: mem=16m
Memory: 14968k/16M available (1008k code, 20k reserved, 384k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0e:8
c
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
kmalloc: Size (149120) too large
Does anyone have an idea?
#74342 - 23/02/2002 15:25 Re: player hangs at boot logo [Re: test123]
I suspect Emplode buggered your config.ini file, making it so large that the kernel cannot alloc enough memory to read it for Hijack.
Use FTP to fetch/edit/fix /empeg/var/config.ini, or de-install Hijack so it will boot up, and then fix the config.ini file.
#74343 - 23/02/2002 15:33 Re: player hangs at boot logo [Re: test123]
Actually, I'll put out a Hijack v209 in a few minutes, which just skip's the config.ini if the kmalloc() fails.. so perhaps the player may die instead of Hijack.
#74344 - 23/02/2002 15:37 Re: player hangs at boot logo [Re: mlord]
Okay, v209 is out there, with handling for "not enough memory" for loading huge config.ini files.
