#74369 - 23/02/2002 19:00 Synching music and playlists questions...
damone
First Question: Is there any way I can make the emplode program automatically upload new files on my computer to the Rio? It would also have to put the links in the right folders on the Rio because I have each artist in a separate folder.
Second Question: When I play a playlist on the Rio it will stop at the end of that playlist. How can I make it automatically continue on to the next playlist?
#74370 - 23/02/2002 21:41 Re: Synching music and playlists questions... [Re: damone]
mschrag
Loc: Richmond, VA
I don't know about Emplode, but jEmplode will allow you to drag-n-drop a directory and it will recurse through the folders and skip duplicates -- This is not _exactly_ what you want, but as long as your directories stay the same, it should roughly approximate it (i.e. any new songs would be added while the ones that are already there will be skipped). It will neither update modified songs nor will it delete songs that you have since deleted on your PC.
Mike
#74371 - 23/02/2002 22:31 Re: Synching music and playlists questions... [Re: mschrag]
damone
Thanks, I will have to try that out.
#74372 - 24/02/2002 03:06 Re: Synching music and playlists questions... [Re: damone]
1) Tag the playlist as "automatically repeat" in emplode.
2) (version 2.0 of the software and later only) Activate the repeat feature using the repeat button on the remote control.
#74373 - 25/02/2002 14:08 Re: Synching music and playlists questions... [Re: tfabris]
That'll just make it repeat the same playlist, not go to the next one. Or is there a feature I'm missing somewhere?
#74374 - 25/02/2002 14:19 Re: Synching music and playlists questions... [Re: wfaulk]
mtempsch
IIRC, once the empeg is playing a list of files it has no knowledge where they came from, therefore the concept of a 'next playlist' isn't valid (what is the next playlist if you're playing the result of a search, or the entire content of the player?)
The closest thing to this is to manually go into the playlist menu and then hold the bottom button; this will warp you to where you last made a select in the playlist hierarchy, allow you to move to the 'next' list manually.
#74375 - 25/02/2002 14:25 Re: Synching music and playlists questions... [Re: mtempsch]
Oli
Loc: Bucks, UK.
how does de-shuffle around work then?
(sorry, this is nearly the same as the post in
"Search track... play rest of album")
Oli.
#74376 - 25/02/2002 14:27 Re: Synching music and playlists questions... [Re: Oli]
mtempsch
Yeah, see answer there
#74377 - 26/02/2002 06:26 Re: Synching music and playlists questions... [Re: damone]
bonzi
The only way is either by playing the parent playlist in the first place, or by appending additional playlists once the first one is playing.
#74378 - 26/02/2002 11:06 Re: Synching music and playlists questions... [Re: bonzi]
Oh, he said NEXT playlist. Oh...
