#74565 - 24/02/2002 16:28 Cant upgrade
duranike
Im trying to upgrade my mark2 from b7 to b11 by serial. it goes through everything fine and then it says finding pump device and site there forever. then it gives me an error that bad pump or something. i even tried manually restarting it during that stage but nothing. can someone give me emplode beta 7 so i can flash with that and then upgrade again. i dont want to go back to 1.03 becuase then ill lose all my marked files and how many times i listen to each track right? or am i wrong? any help?!?! thanks
1st Original Mark I Owner in California: Serial Number 27.
#74566 - 24/02/2002 17:39 Re: Cant upgrade [Re: duranike]
The "pump" error is in the FAQ (do a search on "pump").
Common reasons for a pump error are: Corrupted file (grab it with GetRight instead of your Web browser next time), or possibly a the hard disk cable problem.
#74567 - 24/02/2002 18:44 Re: Cant upgrade [Re: tfabris]
duranike
Re downloaded emplode and beta 11. Im using the same cord i have been using on all the updates since the very begining of time. the more detail thing is that it says "selecting pump device," and it sits there and then gives the error "bad pump response occured during stage 0x25" . It reads everything erases flash writes flash and goes through everything, so it cant be a bad cable right? What is the problem here?
#74568 - 24/02/2002 18:58 Re: Cant upgrade [Re: duranike]
I was not referring to the serial cable. I was referring to the hard disk cable that internally connects the hard disk drive to the player.
#74569 - 24/02/2002 19:05 Re: Cant upgrade [Re: tfabris]
duranike
on my computer? or on my player? becuase i can change my logo through the serial.
#74570 - 24/02/2002 19:12 Re: Cant upgrade [Re: duranike]
duranike
is there suppose to show the screen when connected to the home ac adapter mode. becuase nothing comes up but the flashing light. it works fine in my car though
#74571 - 25/02/2002 07:57 Re: Cant upgrade [Re: duranike]
guardian__J
Loc: MI, USA
on your player...
and changing the logo has nothing to do with it because it is not stored on the harddrive, it is in the flash.
The flash is not harddrive.
guardian__J
MKIIa 20g Smoke
#74572 - 25/02/2002 11:12 Re: Cant upgrade [Re: duranike]
Duranike. Click here please. You need to contact support.
#74573 - 02/03/2002 13:07 Re: Cant upgrade [Re: duranike]
duranike
I connected to hyperterminal. Here is what i got
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 ([email protected]) (gcc versi
on 2.95.3 20010315 (release)) #8 Fri Feb 8 18:48:15 GMT 2002
Processor: Intel StrongARM-1100
empeg-car player (hardware revision 9, serial number 30102348)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:2
c
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
is this bad? unable to mount? so how i repair my broken cable? ive installed new logos and hijack. does this matter?
#74574 - 03/03/2002 07:08 Re: Cant upgrade [Re: duranike]
David
Loc: Cambridge
You have a faulty drive cable contact support and I'll replace it. However, the line 'Could not find CS4231A (version=80)' means you also have a faulty chip on the mainboad. I'll need to bring your player in for service.
#74575 - 03/03/2002 16:20 Re: Cant upgrade [Re: David]
duranike
Can someone send me emplode beta 7. im having problems with player and i cant only upload with beta 7 but yet i deleted it. please help me
#74576 - 03/03/2002 22:05 Re: Cant upgrade [Re: duranike]
mtempsch
Sent...
