#74597 - 24/02/2002 20:31 MK1 RCA seperate ground adaptor?
stil
Loc: Fort Lauderdale, FL
Among other ridiculously stupid things they did, the shop that previously installed my MK1 threw away the special floating ground "adaptors" which came with my empeg. Needless to say, I will be doing my empeg install myself this time!
Is there a place where I can get these cables? Will it suffice to simply craft them by cutting RCA Y-splitters?
#74598 - 24/02/2002 23:21 Re: MK1 RCA seperate ground adaptor? [Re: stil]
well you have to tell us what place it was so everyone else can avoid it
how did it work without them mine had almost no sound without those adaptors hooked up
#74599 - 25/02/2002 10:07 Re: MK1 RCA seperate ground adaptor? [Re: stil]
Yes, you can easily make your own floating ground adapters. All it does is connect the RCA cables' shields to a ground wire. Go for it.
#74600 - 25/02/2002 10:09 Re: MK1 RCA seperate ground adaptor? [Re: tfabris]
No! Don't make your own! Email David and ask him to send you a set. We're never going to get rid of all the spares at this rate
