#74885 - 25/02/2002 14:49 silly question
spider
would the empeg be considered as a high or low RCA output headunit??
im guessing low? ie. no watts on the unit..
#74886 - 25/02/2002 14:52 Re: silly question [Re: spider]
SE_Sport_Driver
In the car, it is rated as a 4v output. Using the RCA's on the back, while plugged to home power, it is 1v.
#74887 - 25/02/2002 14:53 Re: silly question [Re: spider]
The player has 4v line-level RCA outputs.
The words "high" and "low" are relative, they mean different things in different places. It depends on who's asking the question.
If speaking in terms of line-level-only, it's "high".
If speaking in terms of amplified versus unamplified, it's "low".
What situation are you asking this question for? Please supply more information.
#74888 - 25/02/2002 14:57 Re: silly question [Re: tfabris]
spider
im finally ordering an interface cable for my 2001 nissan pathfinder. im ordering a PAC OEM-1 unit. There are two choices for an "A" cable (cable connecting stereo to pac oem-1), RAD-RCA (4 chan low level) and RAD-UNV (4 chan high level. any ideas or does it even matter.
#74889 - 25/02/2002 15:03 Re: silly question [Re: spider]
SE_Sport_Driver
Be careful, sometime "high-level" refers to "speaker level" which is way stronger than any RCA output..
For example, car audio amps usually have both RCA level and speaker level inputs...
#74890 - 25/02/2002 15:07 Re: silly question [Re: SE_Sport_Driver]
spider
RAD-RCA Universal harness for low level RCA output headunits (4 channel)
RAD-UNV Universal harness high level speaker output headunits (4 channel)
So based on this your saying go with the RAD-RCA? I thought "speaker" was a misprint but I have NO car installation experience
#74891 - 25/02/2002 15:30 Re: silly question [Re: spider]
Ah, cool. Having installed an OEM-1, I have personal experience with this. You want RAD-RCA. In this case, high and low are referring to amplified and unamplified.
Note that the OEM-1 will only work in cars that have a factory amplifier built-in that powers all of the speakers. Make sure your car is one of the ones supported by the OEM-1.
#74892 - 25/02/2002 15:37 Re: silly question [Re: tfabris]
spider
tony,
having used/installed a oem-1 would recommend it?
im asking because i am also looking at a soundgate unit....
#74893 - 25/02/2002 15:40 Re: silly question [Re: spider]
also having used/installed a oem-1 would recommend it.
I think there's a typo or two in that sentence, I believe you're asking me a question, would I recommend the OEM-1?
I think it's very car-specific as to whether it works well for a particular vehicle. For the vehicle I installed it in, it was fantastic and made the installation very simple. Don't know how your car will come out. Photos of and comments about the OEM-1 install I did are here.
