#77059 - 02/03/2002 07:50 Hijack v225: still tackling lock-ups
Okay, v225 is the current version, with a pop-up diagnostic screen for when Hijack detects "stuck jiffies". Similar info also gets logged on the serial port, so if you want to leave it running for a day or three, just leave something connected to serial to see if anything bad happens/happened.
If the player locks up without the debug screen appearing, try using the Hijack menu to display "Vitals v2beta11".
In either case, please report back what you see there (with VERSION NUMBERS for Hijack & player software too, please).
Oh yeah, the v225 font has been updated, so let us know if it's better, worse, or irrelevant.
Thanks.
#77060 - 02/03/2002 08:00 Re: Hijack v225: still tackling lock-ups [Re: mlord]
Nosferatu
Loc: France, Champagne
Thanks Mark for the Return ....
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#77061 - 02/03/2002 08:04 Re: Hijack v225: still tackling lock-ups [Re: mlord]
And it's back up until SourceForge goes bust (which could be sooner than one might think).
#77062 - 02/03/2002 08:23 Re: Hijack v225: still tackling lock-ups [Re: mlord]
Laura
Loc: Greenhills, Ohio
Yes, welcome back, glad you returned.
Not good news about SourceForge though.
Laura
MKI #017/90
whatever
#77063 - 02/03/2002 08:26 Re: Hijack v225: still tackling lock-ups [Re: Laura]
Rumour, not news.
#77064 - 02/03/2002 08:30 Re: Hijack v225: still tackling lock-ups [Re: mlord]
Nosferatu
I have been told this rumour long time ago ...
#77065 - 02/03/2002 10:08 Re: Hijack v225: still tackling lock-ups [Re: Nosferatu]
KungFuCow
Mark, if SourceForge does go bust, I think I would be able to offer you hosting for Hijack.
Anyway, after Bruno's suggestion, I reinstalled b11 consumer image and the player has been humming along happily for about 12 hours with no lockups whatsoever.
I'm going to reinstall HiJack and see what the results are.
#77066 - 02/03/2002 10:09 Re: Hijack v225: still tackling lock-ups [Re: mlord]
ellweber
Loc: Saratoga, CA, USA
Mark,
I just had a very brief button lock up that produced the following on the serial port:
DEBUG: bug=0, jiffies=537676, cr:9d6cb700, mr:9d6d0000, sr:00000000
DEBUG: bug=0, jiffies=541446, cr:a5b5174f, mr:a5b5a000, sr:00000000
This is with Beta11 and 225.
This was of very short duration (several seconds only) and resulted from exiting the Hijack menu with a "Top" button press. Previously I had been seeing the 20 minute (19 perhaps) self recovory type lock ups from time to time. The vitals beta11 screen was moving right along by the time I got to it so any data from it would be considerably after the problem had resolved itself.
OOPS!!! Now I am thinking that this message comes out everytime I try to look at the Vitals v2beta11 screen, sorry for the false alarm.
Thanks for demonstrating a level of maturity that should be an example to those few that feel the need to be critical of someone else's behavior when their own behavior is less than exemplary. How's that for a run-on sentence!
Lynn
Edited by ellweber (02/03/2002 10:32)
#77067 - 02/03/2002 11:36 Re: Hijack v225: still tackling lock-ups [Re: ellweber]
KungFuCow
Okay, reinstalled Hijack 225 after testing for 12+ hours without it and it locked up in about an hour. Hard lock, no music, no visuals however the HiJack menu can be accessed. Strangely the Vitals screen is still active so Im not real sure what to report. The Jiffies counter is incrementsing and the in, ti, cr and mr counters are also still active. The sr counter is 00000000.
Probably not much help since the diagnostic message was still scrolling.
#77068 - 02/03/2002 12:26 Re: Hijack v225: still tackling lock-ups [Re: KungFuCow]
Mmm.. okay, that confirms for us that your lockup is different from the "jiffies" lockup others have seen.
Thanks. (no idea what to do next on that one, though.
#77069 - 02/03/2002 18:13 Re: Sourceforge [Re: mlord]
bonzi
What, VA-whatever-they-are-called-today withdrawing the support? Hm, there are no VA logos neither on Sourceforge.net nor on osdn.com any more. There is an IBM banner, though. Maby some money will come from Lou or Larry...
#77070 - 02/03/2002 19:18 Re: Hijack v225: still tackling lock-ups [Re: mlord]
I'm sure you'll have people donating some web space if you ever need it. I know that with SF, it's mostly a convenience thing.
BTW, do you know what kind of bandwidth has been eaten in a typical month with HJ downloads?
#77071 - 03/03/2002 09:15 Re: Sourceforge [Re: bonzi]
Now now.. mere rumour (and market anticipation), not fact.
Sourceforge's masters have gotten out of hardware, dumped Linux from their name (but not their stock ticker symbol), and appear to be preparing to "donate" SourceForge to the "community" (my words, my intuition, not theirs).
IBM is stepping in to take on some of it, so it won't die immediately when VA-whatever goes bottoms up. After that, who knows.
Pure rumour.
#77072 - 03/03/2002 09:27 Re: Hijack v225: still tackling lock-ups [Re: hybrid8]
No, but I can guess.
Hijack was originally hosted on my own server (across the room from me), at the end of a 2.2/1.1 mbit/sec ADSL line. By January, there were hits on the site at least once a minute, 20 hours a day. I suspect that more than a few people run background scripts probing for new versions of Hijack.
Of those hits, a 500KB kernel download occured perhaps once an hour on average (more often immediately after each release, less often in slack intervals).
Then I moved the site to SourceForge, in an effort to stay "under the radar" of my ISP (the terms of service are muddy at best, but the speed is good and the cost is cheap). This coincided with a massive influx of new users on the BBS, so I suspect by now the download rate may be double what it once was.
I'm lousy at math, except when it counts (pun intended).
#77073 - 03/03/2002 10:02 Re: Hijack v225: still tackling lock-ups [Re: mlord]
That's still only 1116MB per month with triple the volume. If you ever need a mirror I'd put one up in a flash.
#77074 - 03/03/2002 10:03 Re: Hijack v225: still tackling lock-ups [Re: mlord]
After installing v225, I had 2 solid locks, nothing worked. This is with beta 11 on a MK2a, and the first time I have seen a hard lock with this version.
Serial was connected both times, and the last lines were simply the serial notify I have enabled. The web server was unresponsive, as was the buttons on the unit. The display was frozen, and audio stopped. I dodn't try to ping the unit though. The first lock happened when I pressed play to resume the playlist, the second lock occured when it was playing after the reboot.
I;ve since rebooted it and it seems fine for now, playing longer then before. v225 has been flawless on my MK2a at home.
And a suggestion, have the serial debug code enabled at all times, not just when in the Vitals beta 11 screen.
#77075 - 03/03/2002 10:06 Re: Sourceforge [Re: mlord]
If it does go away, my offer still stands on a Riocar.org section (with an SCP accessable file storage, not that web crap I showed you earlier).
Though I doubt sourceforge.net will ever completly go away. It's too valuable to many companies. Compaq for instance uses it for all their open source drivers. Compaq has also been known to donate hardware when needed (kernel.org is a recent example). And as you said, IBM has also shown interest. Now that the big companies like Linux, not much will kill a good part of it.
#77076 - 03/03/2002 10:07 Re: Hijack v225: still tackling lock-ups [Re: drakino]
It already is, in v225.
#77077 - 03/03/2002 10:40 Re: Hijack v225: still tackling lock-ups [Re: mlord]
Odd, I just checked Breakout to confirm I am running v225, and the only time it is outputted is when I am in the Vitals screen:
DEBUG: bug=0, jiffies=440412, cr:c7b54835, mr:c7b57000, sr:00000000
And an update to the lockup, just had a 3rd solid lock when the plaer was paused. One thing I had forgotten to do last time was actually try pressing the knob down. It worked, even thoulg the web server is dead. Pinging the empeg works though, so some of the kernel is still alive.
When I went into the Vitals screen, it continued to count normally. The last 2 lines from the serial port when I was in that acreen are:
DEBUG: bug=0, jiffies=439075, cr:c4c4ef46, mr:c4c56000, sr:00000000
#77078 - 03/03/2002 11:17 Re: Hijack v225: still tackling lock-ups [Re: drakino]
Was it still locked up when you quit from vitals?
#77079 - 03/03/2002 11:38 Re: Hijack v225: still tackling lock-ups [Re: mlord]
KungFuCow
Sounds like Drakino is having my lockups now. I don't feel so alone anymore
#77080 - 03/03/2002 12:31 Re: Hijack v225: still tackling lock-ups [Re: mlord]
Yes it was. But I could go back into Hijack.
One other thing I haven't tried yet is dumping out to the shell. And nevermind, just had lock #5 after a minute of rebooting, and I can't do anything on the serial console.
Just checked the other vitals screen, it shows this on the bottom two lines:
Cac:959,Buf:82,Fre:88
LoadAvg:17.21 7.40 2.89
(And the load is climbing)
Any chance of getting a "ps aux" dumped to serial somehow from the hijack menu? Whenever this happens on mine, nothing else is accessable.
#77081 - 03/03/2002 13:13 Re: Hijack v225: still tackling lock-ups [Re: drakino]
Never mind, found the problem after turning on verbrose HTTP reporting:
khttpd: 16.112.144.31 connection from 16.112.147.66
khttpd: GET "/scripts/root.exe?/c+dir"
khttpd: GET "/MSADC/root.exe?/c+dir"
khttpd: GET "/c/winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/d/winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/scripts/..%255c../winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/_vti_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/_mem_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/msadc/..%255c../..%255c../..%255c/..%c1%1c../..%c1%1c../..%c1%1c../winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/scripts/..%c1%1c../winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/scripts/..%c0%2f../winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/scripts/..%c0%af../winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/scripts/..%c1%9c../winnt/system32/cmd.exe?/c+dir"
khttpd: GET "/scripts/..%%35%63../winnt/system32/cmd.exe?/c+dir"
*sigh*, time to call the IM guys again and tell them to do their jobs.
#77082 - 03/03/2002 13:13 Re: Hijack v225: still tackling lock-ups [Re: drakino]
KungFuCow
I also could get back into HiJack. I'd say that whatever you're seeing is also the same thing I am seeing. Now, did you see this without HiJack also? I ran my player nonstop on shuffle for like 15 hours with the b11 consumer image only installed and never had a lockup. Reinstalled HiJack and got two inside of 90 minutes. Interestingly enough too, this seems to happen a lot more on AC power.
** EDIT ** Hmm.. well, I dont think that's my problem. I have port 80 closed. Im going to plug the player in and let it run not connected to the network and see what happens just to satisfy my curiousity.
Edited by KungFuCow (03/03/2002 13:21)
#77083 - 03/03/2002 13:38 Re: Hijack v225: still tackling lock-ups [Re: drakino]
Mmm.. I don't see how this locks up the player, though.
Mmm..
#77084 - 03/03/2002 13:49 Re: Hijack v225: still tackling lock-ups [Re: mlord]
Not sure either, but it's happened ever since the http server has been in Hijack, and Nimda makes a return visit to the network here.
#77085 - 03/03/2002 13:52 Re: Hijack v225: still tackling lock-ups [Re: mlord]
Okay, so for at least testing purposes then, set khttpd_port=81 and then see if you can reproduce anything.
Perhaps
#77086 - 03/03/2002 13:54 Re: Hijack v225: still tackling lock-ups [Re: drakino]
Perhaps it's just the network activity that is causing some critical section somewhere to get interrupted, triggering the bug. In which case we might reproduce by just browsing playlists while playing.
Or maybe the player gets really confused by the drive spinning up unexpectedly in response to the HTTP request ? seems odd. Any drive icons visible during the lockup?
#77087 - 03/03/2002 13:56 Re: Hijack v225: still tackling lock-ups [Re: mlord]
Who all is using v225? If you saw "stuck jiffies" with previous versions, let us know here whether they've vanished with v225.
#77088 - 03/03/2002 14:00 Re: Hijack v225: still tackling lock-ups [Re: mlord]
mtempsch
I'm one. Saw two stuck jiffies with 224, haven't seen one (yet) with 225...
