#78380 - 07/03/2002 14:19 extern declarations help!
genixia
This is really directed to Mark, although if anyone else can answer, then feel free...
I have added a function to empeg_mixer.c that needs to access a table in hijack.c . The table is of type hijack_db_table_t that is typedef'd in hijack.c
So, I put the following in empeg_mixer.h:
typedef struct hijack_db_table_s {
char *name;
unsigned int dbvalue;
} hijack_db_table_t;
extern const hijack_db_table_t hijack_db_table[25];
but I still get undefined reference errors when linking special.a
By declaring the table as extern in hijack.c as well, everything compiles, links and works, but I get a compiler warning:
hijack.c:411: warning: `hijack_db_table' initialized and declared `extern'
How do I get rid of this warning?
#78381 - 07/03/2002 15:27 Re: extern declarations help! [Re: genixia]
Move the typedef to hijack.h ("find . -name hijack.h"), declare the table itself in hijack.c with NO extern or static keywords.
Declare it again as "extern" in empeg_mixer.c
Problem solved.
#78382 - 07/03/2002 15:28 Re: extern declarations help! [Re: mlord]
And don't neglect to "#include <asm/arch/hijack.h>" in empeg_mixer.c
#78383 - 07/03/2002 17:17 Re: extern declarations help! [Re: mlord]
genixia
Thanks, although I've just seen The Way That I Was Supposed To Do It(tm) - dereference the table in in hijack.c and pass the results as ints in the function call to the function in empeg_mixer.c
This C stuff is fun, but I haven't quite gotten my head around the .h idiosyncracies
