#78626 - 08/03/2002 08:55 Ethernet broadcasting
cshuttle43
Can someone give me some information on the way that the empeg broadcasts itself out to a network? I'm interested in perhaps disabling because the net police here at work might be slightly peeved if they place a sniffer on this segment and find out someone is running this device on their network.
#78627 - 08/03/2002 09:33 Re: Ethernet broadcasting [Re: cshuttle43]
It doesn't. The broadcast packet is sent from emplode. If you don't run emplode -- no packets.
Actually, that's not strictly true -- if your net police are particularly anal, they might spot the empeg using DHCP to acquire an IP address.
#78628 - 08/03/2002 10:03 Re: Ethernet broadcasting [Re: Roger]
cshuttle43
That shouldn't be a problem; I don't think they're all that anal. Good architecture by design on the part of the empeg, though...
#78629 - 08/03/2002 10:42 Re: Ethernet broadcasting [Re: cshuttle43]
Note that if you're running the Hijack kernel, the player WILL respond to certain packets because Hijack includes an HTTP server. So if you don't want the player making itself known, then don't install Hijack or disable the Hijack features.
Another trick is to put the player on a different subnet, as described here.
#78630 - 08/03/2002 11:02 Re: Ethernet broadcasting [Re: tfabris]
Yeah, but respond to, and originate are two different things.
Otherwise Tony makes a good point -- your sysadmin might run a port scanner to see if anyone's running unauthorised services. Since Hijack is on port 80 (the default http port), more notice might be taken.
#78631 - 08/03/2002 12:51 Re: Ethernet broadcasting [Re: Roger]
justinlarsen
Loc: Petaluma, CA
oh well maybe ill regiseter my empeg ip address to a domain nam,e.. that would be fun
---- Justin Larsen
#78632 - 08/03/2002 20:47 Re: Ethernet broadcasting [Re: cshuttle43]
mschrag
Loc: Richmond, VA
Incidentally, as Roger mentioned, if you run Emplode, Emplode will (by default) broadcast on port 8300 to find all Empegs "within reach". However, if you switch to unicast (i.e. just turn off broadcast in Emplode and specify the IP address of the Empeg), you'll be fine. Mike
