#79307 - 10/03/2002 20:33 Lovely. Frozen at Logo.
mafisto
Loc: St. Paul, MN, USA
Okay, I was in the process of upgrading a friend's Empeg to b11 and during the partition pump power was lost. WHY it was lost is not important (okay, one of my cats stepped on the UPS switch... again) but now the player is frozen at the logo. Watching the boot through telnet, I get the info below. I'm almost certain this is not a hard drive error, but rather something to do with the interrupted upgrade. Any info on how I can restore to factory and start over? There's no music on the thing, but I'd like to get it upgraded and off ASAP. Thanks, telnet log below.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 ([email protected]) (gcc versi
on 2.95.3 20010315 (release)) #8 Fri Feb 8 18:48:15 GMT 2002
Processor: Intel StrongARM-1100
empeg-car player (hardware revision 9, serial number 30102983)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:a
7
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initWarning: unable to open an initial console
your fiend, mafisto
#79308 - 10/03/2002 20:39 Re: Lovely. Frozen at Logo. [Re: mafisto]
Everything looks ok, just apply the upgrade file again. Basicially it looks like it got interrupted when it was writing the new software to the disk, so it boots the kernel fine (thats in flash and was the first part of the upgrade), but then it can't find it's startup files on disk to start the player.
Keep in mind the upgrade won't be able to autorestart your empeg. Pull the plug and power it back up when the upgrade says "Apply power now".
#79309 - 10/03/2002 20:48 Re: Lovely. Frozen at Logo. [Re: drakino]
mafisto
Excellent, thanks for the help. I was a bit nervous about trying to reapply a kernel without knowing the nature of my problem.
I'll go return a copy protected CD in your honour.
your fiend, mafisto
#79310 - 10/03/2002 21:29 Re: Lovely. Frozen at Logo. [Re: mafisto]
BAKup
Loc: Houston, TX
Run the upgrade again, that should fix it.
--Ben
78GB MkIIa, Dead tuner.
#79311 - 11/03/2002 08:13 Re: Lovely. Frozen at Logo. [Re: mafisto]
The upgrade process is designed to be robust. The code on the unit that loads the upgrade is in a protected area of memory, so it theory it is near impossible for a failed upgrade to break anything permanently. Reapplying the upgrade should always fix things.
That Hugo, he's a clever chap...
