#79980 - 12/03/2002 19:53 Streaming Divx - Hijack
ksteele
Loc: QLD, Australia
There are posts on streaming playlists using hijack's http server. This works well for winamp, somewhat for realone, and basically on wmp (which almost looks like it would do nested playlists (+ and -, instead of converting them to a flat playlist, but doesn't work) . This may change into the future...
Using it also to stream .mpg movies and music video clips works fine as well.
What about divx .avi (mpeg-4) clips? It seems to want to download the whole clip locally, before playing.
Is it possible to stream divx in this way, or another way from the player to 'play as you go'? Does it depend on the client software, or is it simply a limitation in the divx format?
Kieran
OZ.
#79981 - 13/03/2002 00:36 Re: Streaming Divx - Hijack [Re: ksteele]
justinlarsen
Loc: Petaluma, CA
the thing with divx, is that has far as i knwo it needs the whoel file before its even playable.. you cant download like part of the avi and have it play.. it needs to be complete.. i havent messed with the new version much so it may have changed.. but thats how it goes as far as i know
---- Justin Larsen
#79982 - 13/03/2002 05:00 Re: Streaming Divx - Hijack [Re: justinlarsen]
ksteele
Loc: QLD, Australia
Pants
Had a feeling.
Thanks for the info.
Kieran.
