#81142 - 15/03/2002 19:16 ProtocolClient restartUnit or restartPlayer?
mschrag
Loc: Richmond, VA
After uploading a new Hijack kernel, should I be calling restartUnit or restartPlayer? I am currently calling restartUnit, but Tony's had some problems with DHCP addresses being reassigned. I notice that after a sync, it only calls restartPlayer, but I don't know if this is "enough" when you put a new kernel on?
Mike
#81143 - 15/03/2002 19:21 Re: ProtocolClient restartUnit or restartPlayer? [Re: mschrag]
Just watch the display: if the animation appears during the restart, then the method you are using is sufficient. Otherwise, not.
#81144 - 15/03/2002 19:29 Re: ProtocolClient restartUnit or restartPlayer? [Re: mlord]
mschrag
Loc: Richmond, VA
I'm talking kernel this time, not animation ... Though the same probably applies -- I can just check /proc/version after the restart.
#81145 - 15/03/2002 20:22 Re: ProtocolClient restartUnit or restartPlayer? [Re: mschrag]
YEah, same applies -- the kernel plays the animation, but only when it is genuinely restarted. So if you see the animation, you know you are running the newest kernel that was downloaded.
