#81146 - 15/03/2002 20:56 jEmplode 26
mschrag
Loc: Richmond, VA
http://www.jempeg.org/jemplode20.jar
Includes:
1) Use Hijack when Possible = default (it checks for /proc/version)
2) Bundled new PNG Decoder
3) AnimEdit - Allow saving of animations with no sequence entries
4) AnimEdit - Modified No-Hijack error message
5) AnimEdit - Fixed off-by-4 error
6) AnimEdit - allows non-digit/letter characters in text entry
7) AnimEdit - "Enter" in text entry = save text
8) AnimEdit - Text properly sets color
9) AnimEdit - Save Frame as PNG
10) AnimEdit - Load Frame from Image
#81147 - 15/03/2002 21:50 Re: jEmplode 26 [Re: mschrag]
Yang
Loc: Raleigh, NC
Minor(?) bug in the selected frame display, the preview images get squished together when you resize the JAnimEdit tool..
More serious bug/issue/annoyance.. Frames are added by inserting selected frames into the sequence.. Unfortunately, if you want to add frames to the end of the sequence, you have to rearrange frames each time you add them in. Also, when inserting into the middle of the sequence, the selected frame (in the right half) doesn't shift to the new frame, so if you want to add multiple ones, you have to continually adjust which frame is selected..
#81148 - 16/03/2002 00:00 Re: jEmplode 26 [Re: mschrag]
Er umm... hmm. I tried this out for the first time (hijack 242) and when I upload animations it says "upload complete" but it's completely blank when I reboot. Selecting "clear animation" brings tux back, but I can't get my animations to work. I even tried a simple one with just one or two frames and it wasn't working at all. Any idea what I might be doing wrong?
Edit: Nevermind, P.E.B.C.A.K. I just figured out that I need to add each frame to the pane on the right hand side.
Edited by yn0t_ (16/03/2002 00:09)
#81149 - 16/03/2002 08:11 Re: jEmplode 26 [Re: Yang]
mschrag
Loc: Richmond, VA
Both fixed in 27.
#81150 - 16/03/2002 08:11 Re: jEmplode 26 [Re: tonyc]
mschrag
Loc: Richmond, VA
There's a warning in 27 for this and a help file that talks about how to use JAnimEdit.
