#81804 - 18/03/2002 07:15 Question about the Negative Spike diode fix...
Let's suppose that I wanted to put the Negative Spike diode fix (described and illustrated here in the FAQ) onto my Mk2 player as part of a debugging effort.
But let's say I didn't feel like ripping apart my dash to get to the wiring behind the sled to add the diode.
And let's also assume that I was going to be working inside the player itself anyway (to add the dimmer capacitor fix).
Can the diode fix be easily applied inside the player's casing? Is it pretty obvious which pin it is? Is there enough space for the diode in there?
#81805 - 18/03/2002 08:13 Re: Question about the Negative Spike diode fix... [Re: tfabris]
David
Loc: Cambridge
I have done a 'how-to' video for fitting an internal diode. I'll release it soon.
#81806 - 18/03/2002 10:11 Re: Question about the Negative Spike diode fix... [Re: David]
Whoa, COOL.
How soon? I was planning on buying the diode and doing the work tonight.
#81807 - 18/03/2002 20:28 Re: Question about the Negative Spike diode fix... [Re: tfabris]
Okay, I went ahead and did it myself, inside the case. Essentially the same thing as what I would have done outside the case (the wire is orange and everything), I just did it more carefully.
