#81908 - 18/03/2002 14:53
Trouble with MSN messenger
At the risk of being lynched by the Linux guys over here ![](/images/icons/wink.gif) , a question about MSN messenger.
When I'm using MSN I can chat with friends, but I can't send files. Calling each other also doesn't work.
I can receive files my friend sends however.
I suspect this has everything to do with my router with built-in firewall. It's a UsRobotics USR8000 router. Now I know that I must allow more ports to be used or something like that, and I think I even found which ports on the microsoft site ( here), but I don't know how to do this.
Can anybody help me?
Thanks!
#81909 - 18/03/2002 15:21
Re: Touble with MSN messenger
[Re: BartDG]
if you can receive files, then you should be okay, if you can't send, i would think it's on their side, and they need to open ports if they are on a firewall. Have you confirmed that the people you are sending to can receive from others?
#81910 - 18/03/2002 15:30
[Re: darwin]
Yes, My friend is not behind a firewall and can receive files through MSN from all his other contacts.
I'm still browsing in my router setup screen, and I think I may have stumbled upon something, but I don't know how to implement is.
Under 'special applications', I've got a screen with 8 ID's which I can fill in. In need to fill in a "Trigger" (don't know what this is), and then the 'incoming ports'. When I fill in trigger '1' (eg), and the ports 5004 – 65535 (like that MS page states) it doesn't work, when I press 'save' the ports I typed in dissapear. And then it doesn't work of couse.
There are some pre-defined options, like eg. "MSN gaming zone", which is trigger 47624 and ports 2300-2400,28800-29000. Unfortunately, this still doesn't allow me to send files.
Any help would be appreciated.
#81911 - 18/03/2002 15:32
[Re: BartDG]
For most Instant Messenger programs, a firewall will prevent things like direct-chat and file-transfer in two ways:
1) Blocked ports (as you already surmised), but more importantly, it can also be caused by:
2) NAT (Network Address Translation). Many of the Instant-messenger programs won't tolerate a layer of NAT between two clients trying to directly connect to each other for certain features.
If it's simply a question of blocked ports, you can open those up at your own risk. But if it's a NAT issue, you might be out of luck.
#81912 - 18/03/2002 15:43
I've tried ICQ tonight, and that works fine to transfer files. But I'm not going to use ICQ since none of my contacts do.
I'm not really sure what this means. Smarter programming by the ICQ guys than the MS guys?
In the link I posted earlier, it states that I need something like a "UPnP–enabled NAT device". I don't know what this is. Is this a feature my router should be capable of for it to work? I think I'll go and check out some specs on USR's page then first.
Also, if it is an NAT issue, could this be adressed by an update of MSN messenger in the future? (if they wanted to of course) Or is it a limitation of my router itself?
#81914 - 18/03/2002 16:03
[Re: BartDG]
Loc: MI, USA
maybe you should try Trillian ( www.trillian.cc )
I twill allow you to connect to MSN Messenger service using a nicer cleaner looking interface, also you can connect to ICQ, AIM, and Yahoo! at the same time with just one program.
guardian__J MKIIa 20g Smoke
#81915 - 18/03/2002 16:11
[Re: guardian__J]
Trillian is nice, but I don't think it supports file transfers in the MSN messenger part of its interface yet. They only just got done adding file transfers to the ICQ part of its interface.
Could be wrong...
#81916 - 18/03/2002 16:15
Loc: MI, USA
oh, sorry...I don't use MSN...
I do know they work with ICQ and AIM already...
(I was just trying to spread the word about a great piece of software ![](/images/icons/smile.gif) )
#81917 - 18/03/2002 23:23
MSN actually got file transfers before AIM and ICQ ![](/images/icons/smile.gif) (In Trillian, that is...)
#81918 - 19/03/2002 02:30
[Re: guardian__J]
Thanks for the Trillian suggestion, but this is no good to me because I don't use any other instant messenger than MSN. (because none of my contacts do, so there really isn't much point to)
It looks like the only thing I can do is wait and hope the MS programmers will get their head out of their <censored> and start doing some decent programming.
Of course, I've been wishing that for years now...*sigh*
#81919 - 19/03/2002 15:04
[Re: BartDG]
Loc: Dallas, TX
well, if trillians file transfer implementation works and msn's doesnt, then it would be worth your while. :-)
#81920 - 20/03/2002 05:31
[Re: Terminator]
You're right, I guess there's no harm in trying it. I'll try it tonight.
#81921 - 20/03/2002 07:53
[Re: BartDG]
Keep in mind it should import all your MSN buddies, but I am not sure if it updates them if you move them out of the MSN Exports folder. So if you add anyone beyond your list with Trillian, then go back to MSN, they might not be there. I haven't tried this personally, as MSN messanger has been loaded on a system of mine for no longer then 20 mins.
#81922 - 20/03/2002 08:50
[Re: drakino]
![](/images/icons/smile.gif) I can understand that.
So, now I've put trillian on my system. I'm curious to see if this will work, but I'll have to wait until my friend gets home tonight before I can try.
Also, Drakino, I've seen in another post you entered today (ethernet-general forum) that you state that XP does uPnP. Doesn win 2000 do this too? Because according to the MS, that's the reason why I'm having problems. Or is this dependent on the capabilities of my router and not the OS on my PC?
Thx!
#81923 - 20/03/2002 10:27
[Re: BartDG]
Yes, Windows 2000 supports uPnP as well, but keep in mind it only kicks in of you have not manually set an IP, or if you haven't been assigned one from another device. Easiest way to check is to go to start, run, and type in cmd. Then type ipconfig and hit enter. If the IP is 169.254, it's possibly uPnP.
#81924 - 20/03/2002 11:26
[Re: drakino]
I've tried what you said, but my IP is 192.168.123....
I guess this is because the IP is provided through DHCP by my router.
So when it comes to uPnP, I'm SOL?
#81925 - 20/03/2002 11:41
[Re: BartDG]
That means you are not using uPnP. How it affects your situation, I am not sure.
#81926 - 21/03/2002 08:39
[Re: drakino]
Ok, I've tried Trillian, but what I expected happened : nothing.
I guess I'm stuck with MSN as-is, with all it's flaws...*sigh*
#81927 - 21/03/2002 11:25
[Re: BartDG]
Loc: MI, USA
MSN must use a different port for file ports then all the others then, that's pretty dumb. Do you know what port it is? or where on your line it's getting blocked?
#81928 - 21/03/2002 18:25
[Re: guardian__J]
From the MS website :
"To enable voice and video communications with Windows Messenger through a non–UPnP firewall, configure the firewall to allow incoming traffic on UDP ports 5004 – 65535. (are they kidding here?)
For other purposes, enable the following ports:
File Transfer: 6891 (to allow 10 simultaneous file transfers open ports 6891 through 6900)
Application and Whiteboard Sharing: 1503
Remote Assistance: 3389"
I've tried opening port 6891, but that doesn't seem to work (or I'm doing it wrong)
I need to enter a "trigger" (whatever that may be), and the port value. But everytime I click "save", the port value dissapears.
I don't know what I'm doing wrong.
#81929 - 22/03/2002 13:27
[Re: BartDG]
Loc: MI, USA
hmmm...unfortunately I don't know how to configure your router...
Any here have one?
#81930 - 23/03/2002 05:02
[Re: guardian__J]
I found out that with entering a DMZ (demiliatrized zone) IP-adres I can get it to work. Of couse, this has two drawbacks :
1) I have to reboot the PC/router each time I enter this value. So why not leave it you say? Well, a DMZ-ip
2) totally exposes the PC to which that IP belongs. So of couse MSN works, but a pretty high price.
For now, if I want to send a file to one of my contacts I'll use the DMZ option. But I'll keep on searching for another solution.
#81931 - 23/03/2002 14:06
[Re: BartDG]
Okay, I just looked at the manual for your USR8000. A trigger is entered as a port number. When your computer makes a connection to the trigger port number, it activates the incoming ports for that computer. So it looks like you should enter the outgoing port number for MSN (which, I think, is 1863) as the trigger and enter 6891 as the incoming ports in association with that trigger.
As to why it doesn't appear to be saving, I can't tell you. I've never used one of these boxes.
#81932 - 23/03/2002 17:30
Thanks Bitt. I'll try that out tomorrow. I have no way of checking if it will work until my friend gets online so I can send him a file. Which probably won't be until tomorrow.
I did however already enter the values you provided and the router does save them, so I guess we're halfway.
By reading the help of the router I came to the same conclusion you did, but I had no idea what the outgoing port for MSN was. How did you know this? Is this documented somewhere?
Edit : nevermind, I browsed the MSN help file and actually found it. You're correct : open with port 1863, and open port 6891(up to 6900). /me slaps myself in the forehead
Anyway, thanks a million and I'll let you know if your solution does the trick.
Edited by Archeon (23/03/2002 17:39)
#81933 - 24/03/2002 13:19
It WORKS!
Thanks Bitt !!
#81934 - 24/03/2002 15:53
[Re: BartDG]
Yeah, trillian has been really popular. The only reason I don't download it is that I dont' really know that many people who use MSN or ICQ, and everything on AIM works for me.
Just curious, do buddy icons work in Trillian?
#81935 - 24/03/2002 16:22
Yes, all my contacts got imported no problem...
Everything on MSN now works fine for me too now...
#81936 - 24/03/2002 17:49
Loc: Dallas, TX
Yes, buddy icons work.
sean
#81937 - 24/03/2002 18:09
Trillian currently supports everything that the AIM client does. This includes:
Buddy Icons (And browser integration for new ones)
File Transfers
Direct Connect
Multiple user chat
Warnings
Away and back messages
Idle time
Font, color and size changes to the text
Emoticons
It also has the added benefits:
No ads
Better support, post a problem or suggestion to their fourms and there is a good chance someone will pay attention to it
Secure messages with other Trillian users over the AIM network
ICQ like message sending if so desired (where the window closes on send, tray icon blinks instead of a message popping up)
Containers, to have one taskbar entry represent whatever Trillian chat windows.
Tons of skins, and skin support built in
I switched to Trillian from ICQ just because I wanted to have a better client. And now that I have, I have picked up several new people on my contact list from the different networks. It's well worth the switch even if you do only use AIM.
