#83394 - 25/03/2002 13:32 Problems Remapping Wheel Knob
xn00dlesx
I am trying to remap the wheel so when i turn it right it changes visuals, and when i turn it left it changes the info. I have the volume fixed so i want to remap the wheel. I can get it to work...BUT i can no longer use the knob the navigate through playlists or the hijack menu. I have tried various code combinations and cant get any of them to work.
[ir_translate]
00000a=Visual+
00000b=Info
I have tried the following with the .N and the .M added along and combinations of the two. Im sure this is an easy thing to get working but i cant seem to figure it out.
#83395 - 25/03/2002 13:50 Re: Problems Remapping Wheel Knob [Re: xn00dlesx]
I *think* I remember Mark saying something about the knob being special and not IR-translate-able. There was a "knob rotate definition" feature but it was removed, and was limited to changing between existing functionality and "jog wheel" for quickly advancing through tracks.
#83396 - 25/03/2002 14:42 Re: Problems Remapping Wheel Knob [Re: xn00dlesx]
[ir_translate]
knobright=Visual+.N,knobright.U
knobleft=Info.N,knobleft.U
#83397 - 25/03/2002 14:51 Re: Problems Remapping Wheel Knob [Re: xn00dlesx]
OK, I stand corrected.
#83398 - 25/03/2002 18:17 Re: Problems Remapping Wheel Knob [Re: mlord]
svferris
Loc: San Diego, CA, USA
How would you do this if you wanted it to apply only in the Car? Would it be:
[ir_translate]
knobright.C=Visual+.N,knobright.U
knobleft.C=Info.N,knobleft.U
#83399 - 25/03/2002 19:44 Re: Problems Remapping Wheel Knob [Re: svferris]
I think so. But I'd probably just prefix it with ;@DC instead.
#83400 - 25/03/2002 20:28 Re: Problems Remapping Wheel Knob [Re: mlord]
xn00dlesx
PERFECT..... i knew it could be done but just had no clue on the syntax
thanx mark
#83401 - 26/03/2002 20:14 Re: Problems Remapping Wheel Knob [Re: xn00dlesx]
xn00dlesx
Is there a way to goto the previous visual ? I try using Visual- but that just freezes up my empeg.
[ir_translate]
knobleft=Visual-.N,knobleft.U
#83402 - 26/03/2002 20:57 Re: Problems Remapping Wheel Knob [Re: xn00dlesx]
Visual- currently works only if you have a Tuner module.
Working on it..
#83403 - 26/03/2002 22:08 Re: Problems Remapping Wheel Knob [Re: xn00dlesx]
suomi35
Loc: Denver, CO
There you go trying to remap the wheel...
*Might only be funny with a few pints of Guinness in ya*
-Jason
