#83984 - 27/03/2002 15:10 Sychronising 2 Empegs
bodybag
Loc: Southern California
How are those of you with 2 Empegs keeping thier content synch'd. I want both of my players to be identical but haven't figured out how to do it without making identical changes on them both separately in Emplode.
Bodybag - So Cal
Not a Whiner any more!!!
#83985 - 27/03/2002 15:16 Re: Sychronising 2 Empegs [Re: bodybag]
There is a Clone utility that works over USB included with the software. It will clone the lower-serial-number to the higher-serial-number.
Takes forever though.
How's Jemplode doing in this area?
#83986 - 27/03/2002 15:22 Re: Sychronising 2 Empegs [Re: tfabris]
bodybag
Never used Jemplode before, does it have a faster option?
Bodybag - So Cal
#83987 - 27/03/2002 19:56 Re: Sychronising 2 Empegs [Re: bodybag]
justinlarsen
Loc: Petaluma, CA
tony only usb? i thought u could do ethernet as well
Edited by justinlarsen (27/03/2002 19:56)
---- Justin Larsen
#83988 - 27/03/2002 21:56 Re: Sychronising 2 Empegs [Re: justinlarsen]
Yeah, the ethernet version is here, but you need to know Linux to do it.
#83989 - 27/03/2002 22:54 Re: Sychronising 2 Empegs [Re: tfabris]
mschrag
Loc: Richmond, VA
jEmplode can be used to copy tunes across Empegs, but keeping them in sync is not it's forte (right now anyway). All the data is there to pull this off though ...
Mike
#83990 - 28/03/2002 04:43 Re: Sychronising 2 Empegs [Re: tfabris]
Greetings!
Once the empegs are synced for the first time using clone, does it sync deltas or try the whole thing again? I am guessing the whole thing, which would take far too long.
Any time I need to do this, I usually do surgery and copy drive to drive. That still takes a while, but is far better than USB or ethernet throughput.
I know people were working on a hard drive sync. Has there been any progress with that?
#83991 - 28/03/2002 08:19 Re: Sychronising 2 Empegs [Re: pgrzelak]
The empegClone utility does a complete copy. Not sure about jEmplode.
More to the point, empegClone only works over USB, and only works from lower serial numbers to higher.
There's two different ways to do it listed at my website: netcat and rsync. The first also does a complete copy, but is a darn sight quicker than empegClone. The second does a proper synchronisation, and is very quick. I use it maybe two or three times a week.
#83992 - 28/03/2002 08:24 Re: Sychronising 2 Empegs [Re: bodybag]
I use "mirrordir" over FTP from a separate Linux box.
Works like a charm.
