#84089 - 28/03/2002 12:49 what is the resolution (dpi) of the empeg screen?
rockstar
#84090 - 28/03/2002 12:52 Re: what is the resolution (dpi) of the empeg screen? [Re: rockstar]
I never calculated it. The number of PIXELS is 128x32, if that's what you're asking, never measured the display and did the math.
Damn, I think I need to take back what I said about Doug Burnside and math in another thread...
#84091 - 28/03/2002 13:04 Re: what is the resolution (dpi) of the empeg screen? [Re: rockstar]
Well... 128 pixels across 3.2 inches would seem to be 40 dpi horizontally. Vertically, looks to be the same -- 32 pixels across .8 inches.
Another way to look at it would be about .63mm dot pitch.
#84092 - 28/03/2002 13:10 Re: what is the resolution (dpi) of the empeg screen? [Re: tfabris]
rockstar
well what i am trying to do is create a bootup animation. I was going to use flash to do the tweening and either export as an animated gif or frame by fram .png files. The problem i am having is that even a line drawing is coming out shadded, and unreadable/seeable. I really don't want to have to do it fram by frame and draw pixel by pixel. I have thought maybe photoshop and imageready, but there again i am having blur problems, even when i design it at the above dimensions. Any insight?
p.s. you actually referenced a thread and didn't post a link to it are you slackin or just busy?
p.p.s I turned off the smoothing export feature looks a lot better now.
Edited by rockstar (28/03/2002 13:14)
#84093 - 28/03/2002 14:24 Re: what is the resolution (dpi) of the empeg screen? [Re: rockstar]
Yeah, I kind of guessed that you wanted the pixel dimensions of the display rather than the actual resolution (resolution is pixels per physical inch/millimeter).
So I guess we didn't need Doug's math, after all.
#84094 - 28/03/2002 14:33 Re: what is the resolution (dpi) of the empeg screen? [Re: tfabris]
guardian__J
Loc: MI, USA
so how much you going to fine this time?
who's the proceeds going to?
guardian__J
MKIIa 20g Smoke
#84095 - 28/03/2002 14:36 Re: what is the resolution (dpi) of the empeg screen? [Re: guardian__J]
He can't be fined if he's been specifically requested to do math.
#84096 - 28/03/2002 15:08 Re: what is the resolution (dpi) of the empeg screen? [Re: tfabris]
guardian__J
Loc: MI, USA
oh..I must have missed that in the fine print
guardian__J
MKIIa 20g Smoke
