#85995 - 08/04/2002 10:17 Hijack wish
oliver
Hi, I would like to be able to control the led on the frontpanel. I would like it to never blink, maybe an option to turn led off, and on. something along those lines
#85996 - 08/04/2002 12:26 Re: Hijack wish [Re: oliver]
Anonymous
Unregistered
YES!
#85997 - 08/04/2002 13:24 Re: Hijack wish [Re: oliver]
Well then, read this thread and hop to it!
Seriously though, look at Hugo's last response at the bottom and I think you'll understand the Empeg team doesn't really want to touch this one. But they're certainly willing to let someone else do the work (and risk their Empeg's life, note the warning in his "how to" steps) and then contribute the source to the main baseline.
#85998 - 09/04/2002 03:00 Re: Hijack wish [Re: oliver]
jane
Loc: Copenhagen SW, Denmark
Never blink? That's easy.
Take your empeg player to pieces as described in the FAQ.
Cut off or de-soldier the LED.
Reassemble the player.
Problem solved
Marius (Escort Cab + Mark II)
#85999 - 09/04/2002 10:10 Re: Hijack wish [Re: jane]
Heh, either that, or buy a piece of Click 'n Clack handy-dandy black tape.
I used black shrink tubing around mine to reduce the visible size of the LED so that it was not so obtrusive.
#86000 - 10/04/2002 08:57 Re: Hijack wish [Re: tfabris]
smu
Loc: Germany (Ruhrgebiet)
Hi.
Considering the famous black marker mod, I just used a black marker to make my LED less bright. Depending on the type of marker, you have to adjust the brightness either by the number of times you paint the LED (if the marker is not covering completely) or the size of the hole you left while painting it (if the marker eliminates 100% of the light where it is applied).
I used a marker of the second type and left a hole of about 0.5 mm in diameter (about 0.02 inch).
cu,
sven
