#86268 - 09/04/2002 14:19 Jemplode will not find empeg.
Anonymous
Unregistered
I have 2 beta 11 with Hijack, using serial, Windows 98. 2 beta 11 Jemplode can not find the empeg. I know it's a good connection because Rio Emplode finds it. What am I doing wrong?
#86269 - 09/04/2002 14:43 Re: Jemplode will not find empeg. [Re: ]
On the Jemplode page there is a link to a "serial faq"...
#86270 - 09/04/2002 14:44 Re: Jemplode will not find empeg. [Re: tfabris]
... which, if I'd bothered to read it before shooting my mouth off says that it should just work if you're under Windows.
Mike!!!!
#86271 - 09/04/2002 14:46 Re: Jemplode will not find empeg. [Re: ]
SE_Sport_Driver
I've done it finewith win2K.... Does anything else have your serial port? (An open Logo Editor or Hyperterminal)?
#86272 - 09/04/2002 15:03 Re: Jemplode will not find empeg. [Re: SE_Sport_Driver]
Anonymous
Unregistered
I don't think so, I just tried it with no other programs running and it still won't work.
#86273 - 09/04/2002 15:06 Re: Jemplode will not find empeg. [Re: ]
Terminator
Loc: Dallas, TX
It takes a few seconds to find it, its not as fast as emplode. Try manually inputting the ip of your empeg.
#86274 - 09/04/2002 15:37 Re: Jemplode will not find empeg. [Re: Terminator]
An IP for a serial connection. Now that'd be an interesting trick.
#86275 - 09/04/2002 15:56 Re: Jemplode will not find empeg. [Re: Terminator]
Anonymous
Unregistered
Yeah. I don't have ethernet set up.
#86276 - 09/04/2002 16:04 Re: Jemplode will not find empeg. [Re: tfabris]
Terminator
Loc: Dallas, TX
Doh this is what i get for skimming posts. (ppp over serial uses an ip, doesnt it?)
#86277 - 09/04/2002 18:09 Re: Jemplode will not find empeg. [Re: Terminator]
Sure does. And, in fact, many WAN connections are referred to as serial connections, and they definitely have IP addresses. But you know what he means.
#86278 - 09/04/2002 18:44 Re: Jemplode will not find empeg. [Re: ]
mschrag
Loc: Richmond, VA
Can you connect with HyperTerminal?
#86279 - 10/04/2002 09:25 Re: Jemplode will not find empeg. [Re: mschrag]
Anonymous
Unregistered
I don't know. To tell you the truth, I don't even know what Hyperterminal is.
Is there somewhere to select what com to look under in Jemplode? I didn't see any place to set it, maybe it's set on the wrong one. Or is it just by default com 1?
#86280 - 10/04/2002 09:33 Re: Jemplode will not find empeg. [Re: ]
mschrag
Loc: Richmond, VA
Just noticed that Brad had already asked you this ... I would see if you can communicate with the Empeg over Serial _at all_ then come back to jEmplode. Check the RioCar FAQ for how to use HyperTerminal...
#86281 - 10/04/2002 12:21 Re: Jemplode will not find empeg. [Re: mschrag]
Anonymous
Unregistered
Alright I got Hyperterminal to find it while booting up, but it won't let me type commands in. Like in the faq, it says you can type N and press enter and it should goto to the next track. But it does nothing.
#86282 - 10/04/2002 12:36 Re: Jemplode will not find empeg. [Re: ]
mschrag
Loc: Richmond, VA
When you say you got Hyperterminal to "find it" while booting up, what exactly do you mean? It sounds like you've got more sinister serial port issues ... You're kind of on your own figuring those out, but if you get to the point where your serial connection works consistently, try out jEmplode again and let me know how it goes.
Mike
#86283 - 10/04/2002 13:33 Re: Jemplode will not find empeg. [Re: mschrag]
Anonymous
Unregistered
I mean it says this when I plug in the empeg:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v253 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Tue Apr 2 09:58:14 EST 2002
empeg-car player (hardware revision 9, serial number 40104155)
Command line: mem=16m
Memory: 14984k/16M available (1012k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:3
b
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Switching to
After that, I can't control it or anything.
I said earlier that Emplode would work fine with the serial, just not Jempeg, but now I can't even get Emplode to find it.
Any ideas?
#86284 - 10/04/2002 13:38 Re: Jemplode will not find empeg. [Re: ]
SE_Sport_Driver
I'm not sure if you already knew this, or if I already made it clear - so I appologize if that's the case, BUT only one program can have a "hold" of the serial connection at a time. So, if you are viewing that output from Hyperterminal and still have that program open, no other program will be able to use the serial connection. The same goes for the Logo editor or anything else. Once any program is using that serial port - no other program will be able to "share" it. Also, I've noticed that Jemplode takes longer to find the RioCar than emplode (so sometimes it looks like the connection is going to fail but it doesn't). Finally, there were a few times that I had to restart Jemplode to get it to find my player (esp. after changing any of the connection options).
Out of curiousity, why are you using serial? I only use it when using Tony's Logo editor or when sending escher.raw and logo.raw files (and applying player upgrades).
#86285 - 10/04/2002 13:43 Re: Jemplode will not find empeg. [Re: ]
mschrag
Loc: Richmond, VA
Ah -- I missed the one where you said that Emplode can connect with serial
Are you just running with jemplode20.jar, or are you running with a real install of jEmpeg? (i.e. are you running the Exe from the actual installer?)
#86286 - 10/04/2002 13:46 Re: Jemplode will not find empeg. [Re: SE_Sport_Driver]
Anonymous
Unregistered
Yeah, I understood you. I made sure no other programs were running that would use the serial. When I try to connect via serial to emplode now it just keeps searching indefinitely. On Jemplode it just says "No empegs were found" after about half a sec. I was using serial on Jempeg cause I don't have ethernet set up. I was using it on RIo Emplode just to see if it would find it.
#86287 - 10/04/2002 13:54 Re: Jemplode will not find empeg. [Re: mschrag]
Anonymous
Unregistered
I've tried both. One is Jemplode Version 2.0b11 (opened from the start menu) and the other is Jemplode Version 34. I used the installer for one of them, I think the one in the start menu.
#86288 - 10/04/2002 13:57 Re: Jemplode will not find empeg. [Re: ]
SE_Sport_Driver
Maybe one of those programs isn't really shutting down? Did you re-boot?
#86289 - 10/04/2002 14:13 Re: Jemplode will not find empeg. [Re: SE_Sport_Driver]
Anonymous
Unregistered
Just tried rebooting. No luck.
In that big list of stuff from Hyperterminal it says:
Is that anything worth noting?
#86290 - 10/04/2002 16:00 Re: Jemplode will not find empeg. [Re: ]
Nah. Ignore that line, it's normal. It just means that the kernel driver for the serial port built into the StrongARM chip was compiled with no extra options turned on.
- Trevor
#86291 - 10/04/2002 20:57 Re: Jemplode will not find empeg. [Re: ]
Anonymous
Unregistered
Alright it works with Logo Editor. But not like it used to. I used to be able to press 'Send to player' and it would send it right away. Now it gets a ComError in readbyte24 and I have to unplug the player, plug it back in and then it sends the logos fine.
hmm....
#86292 - 10/04/2002 21:07 Re: Jemplode will not find empeg. [Re: ]
When that sort of thing started happening on my system, it was a frayed serial cable. I had to discard it and use a fresh cable, and all was well after that.
