#86655 - 10/04/2002 22:00 Trying 2 Connect thru USB under Windows XP problem
DisOrd3R
Loc: Cleminton, New Jersey USA
Sorry I could not find much that helps me out in the FAQ. Unless I am totally blind.
I'm trying 2 connect using my USB. Emplode does not see the Rio Car. I have had this problem B 4. I would remedy it by unplugging and re-plugging in the USB connections. Eventually XP would see the Rio Car. But it did not work this time. Y not?
BTW, I'm using V 1.03.
Please help. Thanks so very much.
======================================== Mitsubishi Eclipse V6 GT Rio Car 60 Gig unit
#86656 - 10/04/2002 22:18 Re: Trying 2 Connect thru USB under Windows XP problem [Re: DisOrd3R]
robricc
We're all stars now...
in
the
dope
show
(I like your avitar)
#86657 - 11/04/2002 08:47 Re: Trying 2 Connect thru USB under Windows XP problem [Re: robricc]
DisOrd3R
Thx
#86658 - 11/04/2002 11:55 Re: Trying 2 Connect thru USB under Windows XP problem [Re: DisOrd3R]
DisOrd3R
Still need help everyone. Pleeeeeeeeeeez?
#86659 - 11/04/2002 12:05 Re: Trying 2 Connect thru USB under Windows XP problem [Re: DisOrd3R]
The USB driver is simply buggy on XP. This is a known bug. Until the empeg guys get the driver fixed, there is little you can do about it.
In the meantime, the work-around is to use ethernet instead of USB.
#86660 - 11/04/2002 12:10 Re: Trying 2 Connect thru USB under Windows XP problem [Re: tfabris]
DisOrd3R
I'll try it 2 night. Thanks.
Wish me luck.
#86661 - 11/04/2002 12:20 Re: Trying 2 Connect thru USB under Windows XP problem [Re: tfabris]
DisOrd3R
I'm a dunce! I would not know an Ethernet connection from a ground wire. Doh!
It's the small square hole in the back of the Rio Car. That's the Ethernet connection, right? God, I should take a class on electronics.
#86662 - 11/04/2002 13:25 Re: Trying 2 Connect thru USB under Windows XP problem [Re: DisOrd3R]
mtempsch
It's the squareish/rectangular hole with 8 thin contact pins at the bottom. Looks like a larger version of the connector that you can find on most any phone today (normally with 4 connectors).
Looking at the rear of the empeg, from left to right, the connectors are:
power, usb, ethernet, serial, left and right RCA (and the car docking connector at the top right). On my empegs the connectors are all labeled, aren't yours?
Also, if you plug your empeg directly into the network card of your computer, ie not to a hub, you need a crossover ethernet cable. If you do plug it into a hub or switch, you need a straight ethernet cable instead.
