#89784 - 22/04/2002 19:03 stuck at rebuilding database
my roomates MK2a won't get past building database when start it up. it has the beta 2.11 developer player software installed and hijack (not sure what version).
I can't resync or do the other steps described in the faq to force it to rebuild the database because it won't finish booting.
can anyone suggest something to try ?
thanks
#89785 - 22/04/2002 20:53 Re: stuck at rebuilding database [Re: msaeger]
If it won't finish booting, try Ctrl+C before the player app starts.
If that works, let me know and I'll add it to the FAQ.
#89786 - 22/04/2002 21:04 Re: stuck at rebuilding database [Re: tfabris]
hitting Ctrl+C works to get the command prompt but when I do the line "rm /empeg/var/database" I get no such file or directory.
#89787 - 22/04/2002 21:06 Re: stuck at rebuilding database [Re: msaeger]
Hmm. Hope it's not a hosed hard disk.
Anyone?
#89788 - 22/04/2002 21:20 Re: stuck at rebuilding database [Re: msaeger]
burdell1
do you think it might be the hard drive cable being bad? (I just got the new one from Empeg.)
--the roommate
#89789 - 22/04/2002 21:36 Re: stuck at rebuilding database [Re: burdell1]
lectric
Loc: New Orleans, LA
Does the database file exist? I mean , if you go to /empeg/var and ls, what do you see?
#89790 - 22/04/2002 21:42 Re: stuck at rebuilding database [Re: msaeger]
BAKup
Loc: Houston, TX
Hook up the serial to the computer, and post the boot log.
Also, try re-updaing the 2b11 software to get rid of hijack.
--Ben
78GB MkIIa, Dead tuner.
#89791 - 22/04/2002 22:10 Re: stuck at rebuilding database [Re: lectric]
the only file in that directory is config.ini
#89792 - 22/04/2002 22:17 Re: stuck at rebuilding database [Re: msaeger]
lectric
ewwwwkay. Then we're gonna need a bootlog to see what's going on. And even then it's iffy.
#89793 - 22/04/2002 22:33 Re: stuck at rebuilding database [Re: BAKup]
I tried reinstalling beta 2.11 that didn't make a difference
here's the log
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 ([email protected]) (gcc versi
on 2.95.3 20010315 (release)) #7 Fri Feb 8 18:45:38 GMT 2002
empeg-car player (hardware revision 9, serial number 40104261)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004700).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:a
5
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds ToStarting play
er
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
EXT2-fs warning (device ide0(3,4)): ext2_free_inode: bit already cleared for ino
de 5644
de 5646
de 5648
de 5650
de 5652
de 5645
de 5654
de 5647
de 5656
de 5649
de 5658
de 5651
de 5660
de 5653
de 5662
de 5655
de 5657
de 5659
de 5661
de 5663
de 5638
! tunedb_disk.cpp :1224:Datplayer(7): memory violation at pc=0x3ef1bf84, lr=0x
020b2488 (bad address=0x3ef1bf84, code 2)
abase sizpc : [<3ef1bf84>] lr : [<020b2488>]
sp : 5c62ccaf ip : bfffec5c fp : 71eb7ed0
e mismatch err10: ad2feb47 r9 : 1d99a69a r8 : d2296727
ror.
r7 : 95608397 r6 : 3230252a r5 : 28032b8a r4 : dbf7d6ef
r3 : bffffce8 r2 : 00000000 r1 : 00000001 r0 : c004101e
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F7917D Table: C0F7917D DAC: 00000015
Unable to handle kernel paging request at virtual address 71eb7ec4
memmap = C0F78000, pgd = c0f78000
*pgd = 00000000, *pmd = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c00dfba4>] lr : [<c0011948>]
sp : c0f7df58 ip : c0f7df0c fp : c0f7dfa4
r10: 00000002 r9 : c0fa80e0 r8 : 0000000c
r7 : 00000000 r6 : c0f7c000 r5 : c0fa32a0 r4 : 71eb7ed0
r3 : 60000013 r2 : c00fe1e4 r1 : c00dfb88 r0 : c00dfb94
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Process player (pid: 7, stackpage=c0f7d000)
Stack:
c0f7df40: c0011948 c00dfba4 60000013 ffffffff c0fa80f8 c0fa32
a0
c0f7df60: c0f7c000 c0f7dfb8 3ef1bf84 c0011948 020b2488 3ef1bf84 00000002 c00fc9
78
c0f7df80: 3ef1bf84 60000010 ffffffff c0f7dff4 1d99a69a ad2feb47 c0f7dfb4 c0f7df
a8
c0f7dfa0: c0011fd8 c00116f8 00000000 c0f7dfb8 c0009fd4 c0011fcc c004101e 000000
01
c0f7dfc0: 00000000 bffffce8 dbf7d6ef 28032b8a 3230252a 95608397 d2296727 1d99a6
9a
c0f7dfe0: ad2feb47 71eb7ed0 bfffec5c 5c62ccaf 020b2488 3ef1bf84 60000010 ffffff
ff
Backtrace:
Function entered at [<c00116ec>] from [<c0011fd8>]
r10 = AD2FEB47 r9 = 1D99A69A r8 = C0F7DFF4 r7 = FFFFFFFF
r6 = 60000010 r5 = 3EF1BF84 r4 = C00FC978
Function entered at [<c0011fc0>] from [<c0009fd4>]
Code: e1140007 1afffff7 (e814000f) e1a05000 e0436008
Restored terminal settings
RemountinEXT2-fs warning (device ide0(3,4)): ext2_free_inode: bit already cleare
d for inode 5664
Abnormal player termination
Player received signal 11
Starting player
#89794 - 23/04/2002 02:41 Re: stuck at rebuilding database [Re: msaeger]
OK, I don't see any hardware errors (i.e. your cable and disk are probably fine), but this:
EXT2-fs warning (device ide0(3,4)): ext2_free_inode: bit already cleared for inode 5644
means you should check your partition. This is described in the FAQ:
http://www.riocar.org/modules.php?op=modload&name=FAQ&file=index& myfaq=yes&id_cat=8&categories= Known+problems+and+troubleshooting+questions#162
Support the Campaign Against Unnecessarily Long URLs www.campaignagainstunnecessarilylongurls.org
#89795 - 23/04/2002 04:58 Re: stuck at rebuilding database [Re: peter]
when I perform "umount /dev/hdc4 " I get no such file or directory exists.
#89796 - 23/04/2002 05:04 Re: stuck at rebuilding database [Re: msaeger]
As the prolific Mr Fabris puts it: "If you have only one hard disk, you may omit the lines that include /dev/hdc4."
That's you : you only have a one-drive Empeg and so don't need to check your second drive.
#89797 - 23/04/2002 07:42 Re: stuck at rebuilding database [Re: peter]
darwin
Does he only have one disk? 32GB? Possibly a 20 and a 12?
Edit: Nevermind, it's his roomates.
Edited by darwin (23/04/2002 08:35)
#89798 - 23/04/2002 08:34 Re: stuck at rebuilding database [Re: darwin]
burdell1
It only has one 10gb drive. I had it working briefly. I reinstalled the original software, then deleted some tracks (for more space) then reinstalled the BETA. it worked for a little while until I synchronized it again....then it goes back to doing the same thing. I tried it again to no avail.
#89799 - 23/04/2002 08:53 Re: stuck at rebuilding database [Re: burdell1]
This behavior all sounds very strange, as if there's something else going wrong. Perhaps you should officially contact support.
#89800 - 23/04/2002 09:06 Re: stuck at rebuilding database [Re: tfabris]
burdell1
I did....I haven't heard from them yet.....Any other ideas? It wouldn't be from bad MP3 files, would it?
#89801 - 23/04/2002 09:09 Re: stuck at rebuilding database [Re: tfabris]
Greetings!
Are you running hijack? If so, swap to developer and retry the fsck steps.
Tony - a good addition to the FAQ. When troubleshooting disk problems, have the user load and try the fsck with the empeg kernel. There have been a few isolated incidents (like mine) where having hijack loaded may cause panics like this, and having a clean load may be useful for troubleshooting.
#89802 - 23/04/2002 09:12 Re: stuck at rebuilding database [Re: pgrzelak]
burdell1
My roommate took the Hijack off......
#89803 - 23/04/2002 14:08 Re: stuck at rebuilding database [Re: peter]
sorry I missed that part.
#89804 - 24/04/2002 06:06 Re: stuck at rebuilding database [Re: msaeger]
burdell1
ok....the hard drive cable has been replaced and the hard drive has been reformatted. Then, we put the Beta back on and........it still does it! I think it is possessed! Any suggestions?
#89805 - 24/04/2002 06:34 Re: stuck at rebuilding database [Re: burdell1]
burdell1
i just found out that the disk builder program didn't erase the hard drive. Is there another way of clearing out the hard drive?
#89806 - 24/04/2002 08:57 Re: stuck at rebuilding database [Re: burdell1]
Greetings!
Actually, if you have a terminal session open when booting with the disk builder, it will give you an option to force the format / rebuild.
