#90115 - 24/04/2002 11:52 Rio Car does not work in Car
303
Loc: Germany
i just got my Rio Car and it is working pefect at home. but it is not working in my car. it is dead in the car. does anybody know this problem?
#90116 - 24/04/2002 11:57 Re: Rio Car does not work in Car [Re: 303]
SE_Sport_Driver
We need more info. Has it ever worked in the car? Is it powering up but no audio? details details
#90117 - 24/04/2002 12:05 Re: Rio Car does not work in Car [Re: SE_Sport_Driver]
303
Loc: Germany
wow that was fast!!! thx it is brand new. it is completly dead in the car, nothing happend in the car. no power at all in the car. i checked all the connetions five times. i run the latest firm and software (betas). and it is working in home-mode if i have a plug in the powerconnetion on the Rio. strange!!!
#90118 - 24/04/2002 12:20 Re: Rio Car does not work in Car [Re: 303]
Terminator
Loc: Dallas, TX
Did you check the wires on the harness to see if you pulled any out during the install?
#90119 - 24/04/2002 12:22 Re: Rio Car does not work in Car [Re: 303]
Do you have power going to the docking connector? Your wiring in the car is correct? Did it ever work, or was it working there before and doesn't anymore?
#90120 - 24/04/2002 12:28 Re: Rio Car does not work in Car [Re: pgrzelak]
303
Loc: Germany
i just checked the harness it is ok. and i do have power on the connectors. i did not run in the car (dead) it is just running at home!
#90121 - 24/04/2002 12:29 Re: Rio Car does not work in Car [Re: Terminator]
303
Loc: Germany
#90122 - 24/04/2002 12:40 Re: Rio Car does not work in Car [Re: 303]
Terminator
Loc: Dallas, TX
contact support.
#90123 - 24/04/2002 12:42 Re: Rio Car does not work in Car [Re: Terminator]
303
Loc: Germany
i did but it takes forever and i canīt wait to get it going.
thx anyway!!!
#90124 - 24/04/2002 12:55 Re: Rio Car does not work in Car [Re: 303]
Daria
i did but it takes forever and i canīt wait to get it going. thx anyway!!!
i've had to contact them twice, once for each of my players. Neither time did the answer take more than a single digit number of hours; In neither case was trans-Atlantic shipping not the dominating factor in what was involved. If you want "forever" I can tell you what computer vendors not to deal with, but this is definitely not one of those cases.
#90125 - 24/04/2002 12:59 Re: Rio Car does not work in Car [Re: Daria]
303
Loc: Germany
thanxx for your info i hope you are right.
i think i am just a little nervous!
#90126 - 24/04/2002 18:16 Re: Rio Car does not work in Car [Re: 303]
Neutrino
Knowing nothing about your abilities or your install this suggestion may not apply. Have you checked your ground connection? You do have power on both power leads, right? You've checked them with a meter, using the ground wire as the common? I was caught on this when I installed my unit in my CRX. It worked fine until I turned on the lights and then it stopped. I had used the dimmer wire from the car as my ground. It showed ground until the lights turned on but then it went high. If you have another sled or it is easy to remove it from your ride you might want to put it on a table and twist the two power leads together, then connect it to 12 volts through the harness to bench test it. Actually you could do this in the car as well. This would at least confirm where the problem is at. Hope this helps. Good Luck
#90127 - 24/04/2002 22:31 Re: Rio Car does not work in Car [Re: Neutrino]
303
Loc: Germany
wow you are saved my life.
that was it.
it looks l like that the iso standard is not one.
it is different in my car (vw golf III)
thank you very mutch and have a nice day!!!
thankful
#90128 - 24/04/2002 22:44 Re: Rio Car does not work in Car [Re: 303]
acurasquirrel_
Thats in the FAQ...http://www.riocar.org/modules.php?op=modload&name=FAQ&file=index&myfaq=yes&id_cat=3&categories=Car+installation+questions#6
man this is the first time Ive done this
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
#90129 - 25/04/2002 03:48 Re: Rio Car does not work in Car [Re: 303]
SE_Sport_Driver
Ahh... now it makes sense... That's why we need all the info that you can give. VW's have 2 wires crossed. It has happened to quite a few people!
Congrats on your new toy!
#90130 - 25/04/2002 06:02 Re: Rio Car does not work in Car [Re: 303]
The standard is a standard, but that never seems to have bothered VW.
#90131 - 25/04/2002 08:42 Re: Rio Car does not work in Car [Re: rob]
mtempsch
That an existing standard is in place rarely seem to bother companies big enough, ever...
#90132 - 25/04/2002 13:08 Re: Rio Car does not work in Car [Re: acurasquirrel_]
303
Loc: Germany
thank you everybody!
and it is a great toy!!
