#91762 - 02/05/2002 18:42 DirecTiVo + Caller ID
robricc
It has finally been done. Caller ID is able to be superimposed with DirecTiVo boxen. I plan on getting this working this weekend as soon as I can get to Radio Shack to rig-up the serial cable. Vicious.
Read about it here
Get the program here
#91763 - 02/05/2002 18:46 Re: DirecTiVo + Caller ID [Re: robricc]
Suh wheet.
Damn, it's getting harder and harder to justify my sticking with big-dish.
#91764 - 02/05/2002 18:47 Re: DirecTiVo + Caller ID [Re: tfabris]
Then again, the data compression artifacts in that photo are obvious, so maybe I'm still right to stick with my analog system.
#91765 - 02/05/2002 19:11 Re: DirecTiVo + Caller ID [Re: tfabris]
robricc
I'd probably be using the BUD if I had the property... maybe.
Dual tuners on the DirecTiVo combo boxes is a killer app. I would likely be unable to live too long without it.
#91766 - 08/05/2002 12:20 Re: DirecTiVo + Caller ID [Re: tfabris]
Daria
Why, a standalone TiVo won't work with it?
Nothing should actually stop this program from working on a standalone TiVo
#91767 - 08/05/2002 12:27 Re: DirecTiVo + Caller ID [Re: Daria]
robricc
Modems on Standalone Series 1 Tivos seem to not have caller ID capability. My Sony DirecTivo is not responding to the program either. I have another DirecTivo (Philips) that I could try it on, but it is a hacking virgin. I'd rather not pop the seal just yet.
#91768 - 08/05/2002 15:33 Re: DirecTiVo + Caller ID [Re: robricc]
NiCKEL
Loc: Vancouver, BC, Canada
If you read the thread, apparently the Hughes DircTivo units also don't work out of the box. There is a suggestion on connecting a few leads to the modem IC. Apparently the IC supports caller ID and the required hardware is pretty much all there.
Perhaps a similar trick could work on the standalone tivo? (I will be popin mine open tonight to look )
