#91788 - 02/05/2002 23:46 DEC Alpha support
Hi all,
I just recently added a DEC Alpha (running Debian) to my home network. I'd like to be get emptool
compiled for it. I didn't have any luck just running make:
.../emptool> make
../../Make.rules:82: *** You have not defined a valid BUILD type. Stop.
I browsed through the makefiles for a while, but I'm not that much of a Makefile hacker. Anyone else
have this working on an Alpha (or are the original Makefile author) that could give suggestions?
Yeah, I know... JEmplode, but academic curiosity...
#91789 - 03/05/2002 02:46 Re: DEC Alpha support [Re: canuckInOR]
Ahem. RTFM. You get that error on x86 too unless you do "make BUILD=car2 ARCH=pc emptool", as explained in README.srcrel. Unless there's something weirder going on.
This is however likely to be the least of your problems . Is your Alpha little-endian? What's sizeof(int)? sizeof(void*)? (Presumably sizeof(long) is 8)
#91790 - 05/05/2002 21:27 Re: DEC Alpha support [Re: peter]
Ahem. RTFM.
Or, in my case, RTcorrectFM
ARCH=pc
I saw this in the Makefiles (commented out), but I wasn't sure if "pc" was being used as a non-descriptive term for x86, and if the alpha therefore didn't fall into this category...
Yes, 4, 8, and 8.
My reading skills are the pants. Thanks for the kick in the pants.
