#92680 - 08/05/2002 19:29 How well would this work?
Waterman981
Loc: Salt Lake City, UT
Would I have any problem running a Y cable to my Amps. I want to use 2 seperate sources into the same amps. So the single end would be in the amp, the 2 ends plugged into the source decks. I am wondering because I want to add DVD navigaion, probably like the Kenwood, with the touchscreen, and I am going to be hiding the other deck, only having the Empeg visible. And DVD movies would suck if it wasn't in DTS!
-Michael
#040103696 on a shelf
#92681 - 08/05/2002 19:32 Re: How well would this work? [Re: Waterman981]
Waterman981
Nevermind.... I posted on accident, after I realized what the Sony XA-3911 was.... But still what would everyone reccomend for DVD... the outputs for the empeg are fine... but what about a center channel, and sub... just use a second XA-3911? So I still am wondering with that in mind
-Michael
#92682 - 08/05/2002 22:43 Re: How well would this work? [Re: Waterman981]
If you had both DVD and the empeg in the same car, I would do it by running the Empeg into the aux inputs on the dvd system.
#92683 - 09/05/2002 14:18 Re: How well would this work? [Re: tfabris]
Waterman981
I am currently going Empeg to aux in of my other HU, however, how I want to do my dash will only permit 1 head unit, so using the DVD for the volume control will not work easily. But that may be what I am stuck with doing
-Michael
