#94077 - 15/05/2002 07:52 Building Mini Computer Systems
puckalicious
Has anyone built a Via mini-ITX system? I found a retailer here. I was wondering if the Via Eden processor has enough juice to play/stream MP3's or record tv shows onto a hard disk.
#94078 - 15/05/2002 08:00 Re: Building Mini Computer Systems [Re: puckalicious]
Playing/streaming MP3s does not require much juice.
As for recording TV shows to disk.....that will depend on the picture size and endoder quality etc.
#94079 - 15/05/2002 08:13 Re: Building Mini Computer Systems [Re: puckalicious]
robricc
I built a FlexATX system with a VIA C3 700MHz proc. It was fast enough to burn a CD at 16x, play MP3s and browse the web with Windows 2000 all at the same time.
#94080 - 15/05/2002 08:13 Re: Building Mini Computer Systems [Re: Phoenix42]
puckalicious
It only needs to look comparable or slightly better than a vcr recording for me. And I plan on recording at ntsc resolution, is that roughly 320x240? Via also has a C3 processor for that board, is that more powerful?
#94081 - 15/05/2002 08:30 Re: Building Mini Computer Systems [Re: puckalicious]
David
Loc: Cambridge
That's half resolution, but most USB and cheap PCI TV cards can only manage that.
#94082 - 15/05/2002 09:09 Re: Building Mini Computer Systems [Re: puckalicious]
To take the guesswork out of that, get a TV/video card with hardware encoder (e.g. the Miro DC10plus, which has a hardware MPEG2 encoder on it).
You can then re-encode MPEG2 to MPEG4 at your leisure.
