#96847 - 31/05/2002 13:43 FTP file size limit?
leftyfb
Loc: Lowell, MA
Does hijacks ftp server have a filesize limit? I can't seem to upload anything to it over 5mb. Using linux as a client to upload I get a socket write error at 6.41MB
Mk2a 30GB Blue. Serial 030102999
#96848 - 31/05/2002 14:03 Re: FTP file size limit? [Re: leftyfb]
Hijack does not have a file size limit, you are just out of space on the parition you're sending files to. Send them to like drive0/var or something instead. I think this is in the Hijack FAQ.
#96849 - 31/05/2002 14:07 Re: FTP file size limit? [Re: tfabris]
leftyfb
Loc: Lowell, MA
you were right
Thank you.
Is there a way to tell how much space is left on that partition?
df doesn't seem to be installed
#96850 - 04/06/2002 04:59 Re: FTP file size limit? [Re: leftyfb]
Bleh. Don't use the bodge I posted. It can break the filesystem check. I didn't actually use it for long so it was a bit untested...
To fix do this:
rw
rm /etc/mtab
ro
- Trevor
Edited by tman (04/06/2002 07:53)
#96851 - 04/06/2002 07:42 Re: FTP file size limit? [Re: tman]
smu
Loc: Germany (Ruhrgebiet)
This often breaks the filesystem check for people.
#96852 - 04/06/2002 07:51 Re: FTP file size limit? [Re: smu]
Good point. I'll edit the post
- Trevor
#96853 - 04/06/2002 08:20 Re: FTP file size limit? [Re: tman]
leftyfb
Loc: Lowell, MA
Well thanks anyway. What I can do is when I wanna know how much space is left, I can just set that up, check it and remove the link.
