#98282 - 07/06/2002 16:51 PPP and HiJack
gbsallery
Hi,
I might be missing something really obvious here (it's happened before!), but is there any way to get pppd working with a HiJack kernel? I like the Hijack features (so I don't want to go back to vanilla kernels), but I'd also like to get my iPaq talking to the empeg so ppp would be good. Anybody got any pointers?
Gavin
#98283 - 08/06/2002 04:34 Re: PPP and HiJack [Re: gbsallery]
PPP is not enabled in the vanilla kernels, either.
Just grab the Hijack sources and toolchain, reconfigure and rebuild your own custom hijack'd kernel with CONFIG_PPP=y.
#98284 - 09/06/2002 04:07 Re: PPP and HiJack [Re: mlord]
gbsallery
Thanks for that; I knew that the vanilla kernels didn't have PPP either but I wasn't being clear enough :-)
I've got the toolchain, sources and patches, and I've edited the config file. Now what? The usual make dep; make; make modules?
Thanks,
Gavin
#98285 - 09/06/2002 06:23 Re: PPP and HiJack [Re: gbsallery]
export PATH="/usr/local/armtools-empeg/bin:$PATH"
make oldconfig && make dep && make clean && make bzImage
#98286 - 09/06/2002 08:47 Re: PPP and HiJack [Re: mlord]
gbsallery
Hmm; tried that - it makes sense up until "make bzImage", which gives me:
make: *** No rule to make target `bzImage'.  Stop.
A make zImage in the same place gives errors compiling kftpd.c
Any ideas what I'm doing wrong? Thanks for your help on this, by the way - if you've got something better to do today then don't consider this urgent! :-)
Gavin
#98287 - 09/06/2002 09:13 Re: PPP and HiJack [Re: gbsallery]
Oh, my apologies: make zImage
instead of make bzImage (which is what I use everywhere else..)
When it finishes, the file arch/arm/boot/zImage is your new Hijack kernel.
#98288 - 09/06/2002 09:16 Re: PPP and HiJack [Re: gbsallery]
I do NOT get errors compiling kftpd.c with make zImage.
Oh wait.. missed a step (I have scripts to remember/do all of this for me..). Let's try again:
cp arch/arm/def-configs/empeg-car2 .config
make oldconfig && make dep && make clean && make zImage
cp arch/arm/boot/zImage my.kernel.zImage
#98289 - 09/06/2002 09:45 Re: PPP and HiJack [Re: mlord]
gbsallery
Thanks very much; that compiles smoothly, so I'll play with PPP now. Thanks again!
Gavin
#98290 - 09/06/2002 10:23 Re: PPP and HiJack [Re: gbsallery]
You're welcome.
And you're welcome on board, too!
