#99521 - 14/06/2002 14:56
hijack khttpd wish
Loc: Cape Town, South Africa
Hi,
I was wondering if it'd be possible to implement a means of having a GET request that defines what XSL template file is used for the XML output of khttpd? I was thinking the easiest would perhaps be adding another config.ini directive like 'khttpd_style_path=/path/to/styles' and then, to use a specific XSL file within that defined directory, make a GET request like /?fid=940&ext=.xml&style=filename.xsl.
Reason being, I'd like to be able to change style sheets on the fly. Plus, I have an idea to add to CharcoalGray99 so that clicking a link for more information on a certain track will popup a window with full track info... length, size, bitrate, sample rate, etc.
Would this be a possibility, Mark?
Thanks,
Aragon
#99522 - 14/06/2002 16:36
Re: hijack khttpd wish
[Re: Aragon]
Well, apart from the "master style directory" thingie, can you not do this already using the "&style=xxxxxx" feature of khttpd?
#99523 - 14/06/2002 16:37
Or were you suggesting "changing style directories" by editing config.ini and then rebooting, rather than a true "on the fly" capability?
#99524 - 14/06/2002 16:40
Ah, I wasn't aware of this. How does it work? &style=/full/path/to/style.xsl ?
Thanks,
Aragon
#99525 - 14/06/2002 16:43
[Re: Aragon]
Yeah, I think that's the syntax.
(Keep in mind that being a non-MicroSoft user, I cannot see or test any of this stuff, since everyone's existing XML scripts are MicroSoft-specific).
#99526 - 14/06/2002 16:48
I just tried it out. It works! Awesome, that's exactly what I had in mind  *goes to make more mods to CharcoalGray99*
My idea behind the config.ini directive was to save having to specifiy the full path in the &style variable. But, far from serious. This works perfectly.
Have you considered loading windows via vmware? You really should check this out
Regards,
Aragon
#99527 - 14/06/2002 16:50
[Re: Aragon]
I have VMWare (since the early betas..), thanks.
I use it for evaluating new versions of Linux distros.
(and yes, I'll confess, I also use it for PhotoShop under win98se).
#99529 - 14/06/2002 17:39
Hi,
Have been playing with what I'm trying to do and am having difficulty. When doing a get on a tune (not a playlist) with &ext=.xml, an m3u playlist is output. Is it possible to change this behaviour so that the XML information of just that tune is output?
Perhaps in the form:
<item stylesheet="/path/to/style.xsl" host="hostname" allow_files="1" allow_commands="1" type="tune" tagfid="tagfid" fid="fid" year="year" options="options" genre="genre" title="title" artist="artist" source="source" comment="comment" length="length" tracknr="tracknr" bitrate="bitrate" samplerate="samplerate" codec="codec" duration="duration" offset="offset"/>
with no other <playlist> or <items> tags.
OR
In the regular format of "<playlist ...> <items> <item> ... </item> </items> </playlist>" but with that single tune being the only <item>.
Thanks,
Aragon
#99530 - 14/06/2002 20:31
[Re: Aragon]
Mmm.. sounds reasonable.
Remind me in a week or so, or send me a patch.
#99531 - 11/07/2002 17:55
HI Mark,
Here's the very delayed reminder. I think if the feature were added, the former output syntax would be most sensible :
Thanks,
Aragon
#99532 - 28/07/2002 10:14
[Re: Aragon]
Okay, this is in Hijack v286. Note that the request should be formatted for the tags file rather than the .mp3 tune file -- the fid=xxxxx must end in "1".
#99533 - 28/07/2002 17:31
One minor problem. The single <item> tag needs to be ended with /> to comply with XML standards. Single tags (those without <tag> contents </tag>) must be in the form:
<tag param="value" param="value"/>
Thanks,
Aragon
#99534 - 29/07/2002 15:29
[Re: Aragon]
Thanks, the '/' got lost somehow, it's back in for v287.
#99535 - 29/07/2002 16:08
Wooohoo, thank you Mark!
#99536 - 30/07/2002 01:27
[Re: Aragon]
Aragon, this sounds cool. Could you post your altered html page here? I'd quite like to have this functionality as well, and I'm sure others could use it.
#99537 - 30/07/2002 01:59
[Re: frog51]
Hi,
I haven't written anything to take advantage of the new feature yet. However, a new version of CharcoalGray99 should be out soon with code that uses it.
Regards,
Aragon
