#332275 - 21/04/2010 17:36 kernel panic unable to mount root fs
cdodds
Loc: Warren, AR
Need help, haven't used player in about 5 years, thought it was the hard drive at first, but took it out works fine. My player is stuck at the first boot logo RIO, hooked up a serial cable and the got connected.
Error Message:kernel panic unable to mount root fs
Help!!!!!! Let's keep it alive
#332276 - 21/04/2010 17:38 Re: kernel panic unable to mount root fs [Re: cdodds]
Let's start with a full serial boot log and we'll go from there.
#332282 - 21/04/2010 18:57 Re: kernel panic unable to mount root fs [Re: tfabris]
cdodds
Loc: Warren, AR
empeg-car bootstrap v1.02 20001106 ([email protected])
If there is anyone present who wants to upgrade the flash, let them speak now,
or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the kernel
Linux version 2.2.14-rmk5-np17-empeg41 ([email protected]) (gcc versi
on 2.95.2 19991024 (release)) #132 Wed Jan 10 13:49:24 GMT 2001
Processor: Intel StrongARM-1100 revision 11
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.
empeg-car player (hardware revision 9, serial number 30103063)
Command line: mem=16m temp=40
Calibrating delay loop... 207.67 BogoMIPS
Memory: 15048k/16M available (972k code, 20k reserved, 336k data, 8k init)
Dentry hash table entries: 2048 (order 2, 16k)
Buffer cache hash table entries: 16384 (order 4, 64k)
Page cache hash table entries: 4096 (order 2, 16k)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.2
Based upon Swansea University Computer Society NET3.039
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 16384 bhash 16384)
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)
Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 )
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 )
Starting kswapd v 1.5
SA1100 serial driver version 4.27 with no serial options enabled
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART
Signature is 206f6972 'rio '
Logo type is 1
empeg display initialised.
empeg dspaudio driver initialized
empeg audio-in initialised, CS4231A revision 08
empeg infra-red support initialised.
empeg usb initialised, PDIUSBD12 id 0000
empeg state support initialised 0089/88c1 (save to d0005000).
empeg power-pic driver initialised (first boot)
RAM disk driver initialized: 16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
empeg-flash driver initialized
smc chip id/revision 0x0001
smc_init couldn't find card
RAMDISK: ext2 filesystem found at block 0
RAMDISK: Loading 320 blocks [1 disk] into ram disk... done.
VFS: Mounted root (ext2 filesystem).
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs o
e000 v1.03
Copying kernel...
Command line: mem=16m temp=25
Logo type is 1
empeg audio-in initialised, CS4231A revision 19
empeg state support initialised 0089/88c1 (save to d0005080).
Kernel panic: VFS: Unable to mount root fs on 03:05
e000 v1.03
Copying kernel...
Logo type is 1
empeg state support initialised 0089/88c1 (save to d0005100).
e000 v1.03
Copying kernel...
Command line: mem=16m temp=27
Logo type is 1
empeg state support initialised 0089/88c1 (save to d0005180).
#332286 - 21/04/2010 19:51 Re: kernel panic unable to mount root fs [Re: cdodds]
Hook up the hard drive again, then post the output with it connected.
#332287 - 21/04/2010 19:51 Re: kernel panic unable to mount root fs [Re: mlord]
Oh, wait a sec.. install a Hijack kernel first.
#332290 - 21/04/2010 20:05 Re: kernel panic unable to mount root fs [Re: mlord]
cdodds
Loc: Warren, AR
v508.hijack.mk2.zImage
is the one?
#332301 - 21/04/2010 20:57 Re: kernel panic unable to mount root fs [Re: cdodds]
cdodds
Loc: Warren, AR
I did everything and got an error meessage on my player no hard disk found contact support
What's next?
#332302 - 21/04/2010 21:06 Re: kernel panic unable to mount root fs [Re: cdodds]
Post the serial log again, from booting with the Hijack kernel.
#332307 - 21/04/2010 21:40 Re: kernel panic unable to mount root fs [Re: mlord]
cdodds
Loc: Warren, AR
Whether you believe it the ide cable was backwards from when i tested the hard. Thanks a thousand
#332308 - 21/04/2010 21:41 Re: kernel panic unable to mount root fs [Re: cdodds]
cdodds
Loc: Warren, AR
need a FM tuner now!!!!!!!!!!!!!!!!!!!!!!!
