Welcome Lina.
I find that restore Visuals works OK so there must be a difference in your settings. If notify=1 is working properly you will see the FID in the vital signs screen of Hijack. Please check.
You can add the following to your config.ini to do the same thing if the FID shows but Restore DC visuals doesn't.
[ir_translate]
initial.C=bottom.L,null
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
