I can't see Patricks site either - havn't been able to since it was announced
- we may have the same problem esp. if you're in NZ currently.
I suspect its a DNS "zone" problem.
If you're in NZ, are you using Paradise.net [or any ISP that routes via TelstraClear's network? - if so, then you're in the same boat as me so to speak.
I've tried dial up using a different ISP with no luck either.
