This is an interesting thread - it make sme wonder how the original Bose head unit was able to do fading. Did it have a separate control wire or were there simply phasing properties in the audio signal that tell the amp to use the rear vs the front? Does the Bose amp simply split the signal between front and back meaning that signal-wise (not counting amplitude):
Right-Front = Right-Rear
Left-Front = Left-Rear
If this isn't the case, then what would control the signal difference between front and back.
I'd be curious to know if you found that your rear speakers worked again when you reverted back to version 1.0.
Brent
RioCar MK][a 20GB+80GB
'96 Saab 900s (Not any more)
Still looking for a good way to install in a 2010 BMW 3 series with iDrive/NAV
