Calvin, your experiences are the reason I prefer to do all installation work myself. If you've got the proper parts and the master sheets from Crutchfield, and you're reasonably good with tools and solder, then you're likely to be better off than having some so-called "pros" do it.
Tanstaafl, did you ever get your master sheets from Crutchfield? What did you think of them?
___________
