A few days ago my empeg suddenly started making an awful noise right in the middle of playing a song which had always worked fine. Since then, it won't boot anymore. It gets as far as starting the player app and then it hangs in an endless loop saying "Loading music databases..." and "Loading playlist..." over and over again.
At the console, the following messages are displayed:
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v340 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Jun 18 18:40:14 EDT 2003
empeg-car player (hardware revision 7, serial number 90000594)
Command line: mem=12m
Memory: 10960k/12M available (976k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005980).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:5
2
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...j)5change_root: old root has d_count=1
Mounting proc
Starting player
Hijack: intercepting config.ini
hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Tuner RDS Control"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta13 2002/07/24.
player(9): memory violation at pc=0x02034e00, lr=0x0216f13c (bad address=0x16173
63c, code 2)
pc : [<02034e00>] lr : [<0216f13c>]
sp : bffffa34 ip : 00000000 fp : bffffa84
r10: 00000000 r9 : 0216f130 r8 : bffffab4
r7 : 00000000 r6 : 0000060e r5 : 0216f0e8 r4 : bffffa40
r3 : 16173638 r2 : 050006c2 r1 : 0216f13c r0 : 0100015a
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: D038117D Table: D038117D DAC: 00000015
Function entered at [<02034cec>] from [<02034ba8>]
r10 = 00000000 r9 = 00000000 r8 = BFFFFAB4 r7 = 00000000
r6 = BFFFFA88 r5 = 0216F0E8 r4 = 021810E4
Function entered at [<02034a90>] from [<02036864>]
r8 = 0210F6CC r7 = 00000000 r6 = 0216F0E8 r5 = 00000C49
r4 = 00000C1F
Function entered at [<02036680>] from [<0202f7f8>]
r10 = 00000000 r9 = 0210F400 r8 = 0214A1A8 r7 = BFFFFD88
r6 = BFFFFD84 r5 = BFFFFD80 r4 = BFFFFD8C
Function entered at [<0202f494>] from [<0202f1e0>]
r10 = BFFFFEE4 r9 = 00000001 r8 = 0214A1A8 r7 = BFFFFEE8
r6 = 00000054 r5 = BFFFFDF4 r4 = BFFFFDF4
Function entered at [<0202f1a0>] from [<020310f0>]
r6 = 00000054 r5 = FFFFFFFF r4 = BFFFFDF4
Function entered at [<02030eec>] from [<0203121c>]
r10 = 020311B8 r9 = 00000000 r8 = 0210F0E8 r7 = 00000000
r6 = 020000C0 r5 = 00000001 r4 = BFFFFF64
Function entered at [<020311b8>] from [<020c5f30>]
r5 = BFFFFF64 r4 = 00000001
Function entered at [<020c5e54>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
The last part (starting with the line "player.cpp etc...") is repeated over and over again.
This has got me scared. Could the filesystem be corrupt? Would it be safe to reinstall an image? How can I determine whether a corrupt filesystem is indeed the problem and if so, how can I fix it and is there any chance of compounding the problem by trying?
Thanks in advance for any help anyone can give!
