After about 20 seconds of fiddleing, i turned off the ethernet support (click on the ethernet bit Connection -> Look for empeg on...) and only had serial enabled. Worked fine. Thats in win2k, 1.01
No, it was the serial cable. I got the null modem adapter and it worked fine after that.
Although, using ethernet at home I am getting an infamous Synch Stage 5 error 0xffffffff. From the posts here it does not seem to be too common of an occurrence. If anyone has any ideas what it could be, I would appreciate it. I sent an email to bugs@ along with a log file as was recommended to another user.
Squid2k1
18GB of Green Mk II Fury - Fast As A Shark
Squid2k1 --- 18GB of revived Green Mk II Fury - Fast As A Shark
