Greetings!
I received a second proof of the answers today. A few good things, and a few not so good things.
+) 42 is now nicely centered and a good size.
+) spacing on "CALL THE HELPDESK" has been corrected
+) "READ THE MANUAL & FAQ" has been changed to "RTFM"
-) They misspelled RTFM as RTMF, probably trying to help / guessing the sequence I wrote was in error
-) The cannot do lower case! They gave a good reason that I can almost agree with. Basically, they claim that the lower case would cause enough of a weight shift to make the answer ball (basically a hollow die floating in inky water) always arrive at the same answers. In the case where the face is lighter, that answer would always appear. I am surprised that they do not have a way to adjust for that, but I am guessing they calculate the weight based on standard fonts that are all upper case...
-) So /DEV/NULL and PING 127.0.0.1 will have to remain upper case
Paul Grzelak
