Yeah, it really isn't a hard thing to do - it can just be a little time consuming. But, if a distro you want to use doesn't have a SMP enabled kernel for you to use, more than likely the kernel you go with in the distro will have the config file to go with it. You can then just change that config file to include smp support and re-compile your kernel form that config. More than likely any distro you go with will also have a step-by-step on how to best config and compile the kernel.
- trs
- trs
